Electrical LED Question
Old Nov 23, 2013 | 09:17 PM
elsenordave's Avatar
elsenordave
LED Question
I changed my map lights to LED w5w bulbs all the other bulbs I changed work fine... The map lights when not on are pin point lit...I tried other bulbs(got a ten pack) and same thing. Any ideas? Will this drain my battery the light given off by then is so minute it almost not noticeable but I don't want my battery to die...any suggestions? Thanks!
Old Nov 24, 2013 | 06:14 AM
othrside's Avatar
othrside
I noticed this issue with mine, I can't imagine the drain being large enough to cause the battery to die, but I could be wrong.
Old Nov 24, 2013 | 09:04 AM
elsenordave
thx I'm not alone in this...
Old Nov 27, 2013 | 04:10 AM
BC_Rob's Avatar
BC_Rob
Are they the Ziza brand?
Old Nov 27, 2013 | 06:53 AM
elsenordave
The stampings on the bulb say samsung.
Old Dec 1, 2013 | 10:59 AM
elsenordave
Anybody!? Don't want to inadvertently kill my battery! Thanks
Old Dec 1, 2013 | 12:24 PM
MaxGSeeker's Avatar
MaxGSeeker
Its unlikely to cause any issue with battery drain. It only takes around 1 milliamp of current to dimly activate an LED. The acceptable range for parasitic leakage current is at least 10milliamps. Quite possibly the LEDs have a lower leakage than the incandescent bulbs you replaced. If you really want to know for sure you would need to jumper in a milliamp meter in series with both the original and new to compare the currents. Like all the MINI lights the computer turns on the actual current, the switch just tells the computer which light to activate. So the computer output is a transistor, which unlike a true mechanical switch always has some leakage current. The transistors were designed to carry several amps, whereas the LED replacement is probably less than a tenth of the same current when full on.
Old Dec 1, 2013 | 02:16 PM
elsenordave
thanks! I appreciate the info.
Old Dec 18, 2013 | 05:38 PM
automan21's Avatar
automan21
I have the same issue, ur not alone. I changed all except the map lights. I don't like them being on even if it's just a wee bit.
Old Dec 18, 2013 | 05:48 PM
danjreed's Avatar
danjreed
Mine do it.
It's part of the pre-run circuit. Your LED in the push to start is on the same circuit.
It powers off after about 15 min.
Not a power drain issue at all.
Old Dec 18, 2013 | 10:19 PM
elsenordave
Originally Posted by danjreed
Mine do it.
interesting...
Colt45Magnus
Aug 27, 2024 05:03 AM
Nine Plan Failed
Oct 14, 2015 11:50 PM
Manny_cooper
Sep 3, 2015 05:48 AM
WayMotorWorks
Aug 25, 2015 10:01 PM
