Electrical any luck getting garage opener to work?
Old Aug 21, 2013 | 10:41 PM
mrgentleminh's Avatar
mrgentleminh
for the life of me i can't get my garage door to sync up with my remote. i follow the instructions, then it flashes fast when both buttons and pressed on the mirror and my remote, and i let go of both and nothing.. =\
any luck anyone?
Old Aug 21, 2013 | 11:19 PM
rkw's Avatar
rkw
If you have a newer garage door opener, it may be incompatible and require a repeater.
https://secure.homelink.com/homelink...ter-kit-detail
https://www.northamericanmotoring.co...rage-door.html
Old Aug 22, 2013 | 05:14 AM
pyrrhusmj's Avatar
pyrrhusmj
And don't forget you have to hit a button on your actual opener after it has learned your remote since most garage door openers are rolling code types.
Old Aug 22, 2013 | 05:36 AM
FourOhFour's Avatar
FourOhFour
any luck anyone?
Is your opener a rolling code type? Look for a "learn" button somewhere on it, probably behind a light cover. Press that, then press the button you programmed in the car.
If that doesn't work, try fresh batteries in the remote… I've found homelink is more sensitive to a weak battery in the remote than the garage door opener is, so fresh batteries can help even if the remote works fine.
Old Aug 22, 2013 | 06:15 AM
k2at11's Avatar
k2at11
How many garage doors can the garage door opener open?
Old Aug 22, 2013 | 09:45 AM
rkw's Avatar
rkw
It has 3 buttons. Each button is programmed separately and operates 1 door.
Old Aug 22, 2013 | 10:16 AM
k2at11's Avatar
k2at11
Tnx RKW
I was hoping it had 3.
danielbrookes_9
Oct 3, 2015 12:51 PM
Bennyboy
Aug 18, 2015 07:28 AM
skippermini
Aug 13, 2015 06:13 AM
SoCalledFriend
Aug 6, 2015 06:59 AM
