Electrical OEM Bluetooth and hands free retrofit kit
Old Jul 30, 2013 | 10:32 PM
Hugo D's Avatar
Hugo D
Hi !
I'm looking in retrofitting my 2010 R55 MINI with a OEM Bluetooth and hands free retrofit kit #65412152530 myself. I wish I could do the job myself, I feel like the car is becoming mine when I do the job myself.
I have the kit but don't get the installing instruction. I'm looking for the correct socket pin-out for connecting the MULF, USB and mic together with the CCC, and also the correct harness routing in the car.
Does any one can help ?
In a further step I will try to install the full audio Iphone USB connectivity with charging and roof antenna in the central armrest...
Best regards
Hugo
Old Jul 31, 2013 | 03:20 AM
yetti96's Avatar
yetti96
From what I have seen, it is possible but the kit might require some install or coding from the dealer (or NCS Expert). Since you are in France and this guy is in the UK, it might be worth looking into. He makes different Parrot kits work with your OEM system and buttons. Truthfully, the stock BT sucks and I wouldn't want you to waste your money on it. I have the OEM BT and leave it turned off as my wife wont talk to me on it and nobody understand me or they just hate talking to me while on BT.
http://www.newministuff.com/new/shop...roducts&cat=36
Old Jul 31, 2013 | 04:34 AM
Hugo D's Avatar
Hugo D
Sure the stock kit requires some install, that's why I'm looking for the manual ;-)
It may be a lost of money to have tried to fit this kit, but what if I dont even try?
My personal experience is disapointing with Parrot's stuff,while BMW's was OK. No reason why it shouldn't be thé same with MINI
Thank you for the add anyway.
Old Aug 1, 2013 | 10:14 AM
yetti96's Avatar
yetti96
No problem, I just know it was a must-have for me in the next MINI, so when I bought this one I was excited and boy was it terrible and I am pissed it was a priority.
Old Aug 1, 2013 | 11:13 AM
Here is the Bluetooth Kit For the Gen 2 MINI. R55 R56 R57 models. You cna click on the item and see all the pics whet come with the kit. Part number 65412152530 . R57 Convertible only requires 51442758451 if they don't already have it & 84109167397 which is the microphone for the steering column location.
MINI Bluetooth Retrofit Kit W/ USB/Audio Interface
http://www.ecstuning.com/Search/SiteSearch/65412152530/ES1599517/
You will need the BMW / MINI ULF module which is separate. BMW / MINI part 84109229740
http://www.ecstuning.com/Search/SiteSearch/84109229740/ES1906933/
Here is a link to a thread on the topic of install. And about #22 post there is a link to the factory PDF install.
https://www.northamericanmotoring.co...bluetooth.html
Then the Y cable for the iPhone connection which is the Audio version. IPod / IPhone Adapter Cable Part number 6112233849
http://www.ecstuning.com/Search/SiteSearch/61122338491/ES2641685/
That is the stock set up.
Additional add on for your modifications
If you trying to add the snap in adapter and use the perfilals from the usb / audio connection , it would take some work. I have never seen it done.
The snap in adapter base for the stock Bluetooth is. Possible someone else could help you with that part of the modification.
Base Plate. Part number 84109201946
http://www.ecstuning.com/Search/SiteSearch/84109201946/ES2674235/
Then of course need the correct snap in for your phone. You will need the audio version snap in adapter for example.
But that's allot of work.
Good luck and hope that helps.
Old Aug 7, 2013 | 01:44 AM
Hugo D's Avatar
Hugo D
Thank you indeed.
Sure it is great help. I should try next week.
I will post some pics of the job if I find it can help.
Old Aug 7, 2013 | 04:53 AM
You are welcome, with the PDF install file you can at least dig through and see what information is valuable to what you are trying to accomplish with a Factory Bluetooth kit + additional.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
mishanja
Jun 22, 2016 09:59 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
