Electrical Remove xenon bulbs
Old Apr 15, 2013 | 01:44 PM
countryman2b's Avatar
countryman2b
Remove xenon bulbs
Hi there,
How to remove the OEM xenon bulbs?
Don't break something
any photos?
Old Apr 17, 2013 | 03:07 PM
countryman2b
nobody can help me?
Old Apr 19, 2013 | 11:31 AM
Shoe Coupe's Avatar
Shoe Coupe
there's a clip to release them you have to undo it i believe and they slide out
Old Apr 26, 2013 | 03:08 PM
countryman2b
Ok but where and how
Old Apr 26, 2013 | 04:35 PM
shmandrew's Avatar
shmandrew
You need to rotate that whole rectangular section (base of the bulb). I forget which way it turns, but it will move. Also need to unplug the plug from the bottom of the base. It's kind of a pain.
Old Apr 26, 2013 | 08:18 PM
MIminiclubman's Avatar
MIminiclubman
Exclamation
You also need to be careful. They have a capacitor that is used to light which has Stored energy in the amps and voltage that can do some real damage. Ie don't start prying open the box unless you really know what you are doing. The warning is real.
Old May 1, 2013 | 01:32 PM
cm.d's Avatar
cm.d
just turn them to the left and it will come out, that's the easy part. getting the wiring plug off, that's the tough part.
Old May 1, 2013 | 01:41 PM
Braminator's Avatar
Braminator
Maybe this will help
Old May 19, 2013 | 06:36 AM
countryman2b
Thanks !!! but it's not the same system on the countryman like you can see in my pictures...
Old May 20, 2013 | 05:41 AM
yetti96's Avatar
yetti96
The countryman shouldn't need new bulbs yet, the oldest cars are 2 years old. The bulbs should last longer. If they did burn up the dealer should be doing these for free. So why the change? But if you insist on changing them then twist and remove igniter (thing on base of bulb) and then remove a clip and the bulb should come straight out.
Old May 20, 2013 | 05:48 AM
countryman2b
I've the 4300K OEM bulbs and i want to put 6000K bulbs (i have the 6000K but i don't know how to make the swap :-( )
minimofo
Nov 16, 2016 05:56 AM
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
greekzilla
Aug 23, 2015 03:44 PM
