Electrical OBD2 Torque Application setting
Old Jan 28, 2013 | 01:04 AM
couper1's Avatar
couper1
Hi
I bought plx kiwi for android.
I bought torque 5 dollar.
Which displays do you use?
What is the setting for CM All4 boost gauge?
Which display shows the engine heat?
There is coolant data, is it right?
It show 90 degrees, is it normal, something down to 60 degrees (celsius)...
Old Jan 28, 2013 | 01:10 AM
couper1's Avatar
couper1
Addition
Is it ok to leave plx always plugged in?
Old Jan 28, 2013 | 07:52 AM
astroBlackMetallic_Mini's Avatar
i have a similar setup, but with a generic bluetooth OBD dongle. i leave mine plugged in all the time, no issues so far.
i use coolant, intake temp, engine load, rpm, boost, manifold pressure, and speed.
you may have other data available, as i have an R53 cooper s
Old Jan 29, 2013 | 11:22 PM
couper1's Avatar
couper1
Coolant data is the engine heat?
Mine is goes to 90 degrees celcius is it normall?
I want to watch boost, what are the settings for boost
Old Jan 30, 2013 | 04:54 AM
? i just scroll down the list. whatever is in GREEN is "available" data from your computer.
you can adjust the Units from C to F. youd have to check what 90C is to F via google.
my mini runs about 200 F on a normal day.
boost should be just labeled as Boost! it was in mine
Dec 5, 2016 06:31 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
