Electrical Trunk alarm coding
Old Jul 7, 2012 | 05:49 AM
Mauro Sciaccaluga's Avatar
Mauro Sciaccaluga
Trunk alarm coding
Hello,
do you guys know what is the right coding to "Panik alarm when hold trunk button" ? I know in USA you should have it by default but I have a UK car. Thank you.
Old Jul 7, 2012 | 07:47 AM
kconner5's Avatar
kconner5
Did you get the alarm as an option? Only cars with the alarm option the US have this feature.
Kyle
Old Jul 7, 2012 | 07:50 AM
Mauro Sciaccaluga
yes, I have but UK cars have this option disabled. I need to know which module and code. thanks
Old Jul 8, 2012 | 12:15 PM
blue dragon's Avatar
blue dragon
If you tell me what module, I can give you a trace. We have this option on our Canadian spec car
Old Jul 8, 2012 | 12:26 PM
Mauro Sciaccaluga
Hi, thanks for the answer.
one guy from bmw coding told it is SONDERTASTE_PANIKALARM (CAS module) which is nicht_aktiv but must be set to akvit
I tried to do that but I got a error with NCS EXPERT and it won't proceed. I suppose it is because I should activate something else before that.
I have no problem to change other codes in CAS or other modules. Just that SONDERTASTE_PANIKALARM I can't change it.
NCS EXPERTS error is:
"Error in CABD! Look at CABI.ERR and ERROR.LOG!
COAPI-1043: error during processing CBD-file CAS3.C09"
I repeat if I try to change other codes everything go fine. Maybe I should activate something else somewhere else.. I am not sure about that.
Any help would be very appreciated. Thank you.
Old Jul 8, 2012 | 12:27 PM
Mauro Sciaccaluga
Also have a look here, they say it should be activated with other parameters but I am not sure if they will work on MINI.
http://www.bmwfaq.com/sitemap/t-683333.html
Old Jul 9, 2012 | 11:22 AM
Mauro Sciaccaluga
aaahhh... I got it... But did not test it yet.
SONDERTASTE_PANIKALARM can be 'nicht_aktiv' or 'panikalarm' no 'aktiv' ahah LOL
Thanks for support anyway...
Old Jul 10, 2012 | 04:33 AM
Mauro Sciaccaluga
Yes, it works I confirm.
You should add this new discovery to your list on page 1.
SONDERTASTE_PANIKALARM nicht_aktiv --> (change to) panikalarm
It will allow panic alarm holding the trunk button on key fob.
carid
Dec 28, 2025 04:11 AM
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
BucksCountyR57
R57 :: Cabrio Talk (2009+)
Sep 21, 2015 05:42 AM
David Eric Rosenberg
Sep 10, 2015 12:34 PM
Gen1Parts
Sep 7, 2015 03:50 PM
