Electrical Any concerns about unplugging Footwell module?
Old Feb 11, 2012 | 10:17 AM
d@g's Avatar
d@g
Before I take my front bumper off to look for a pre-wired fog light connector (not likely), I thought I'd check to see if I had foglight wires coming out of the Footwell module. If not, I know there can't be a pre-wire for the fogs and I can build a wire harness before taking off the bumper to install the OEM fogs.
If I do find the wires exiting the footwell module, I'm going to assume the wiring in the bumper is there. In order to verify, I need to unplug the X14260 and X14261 connectors on the footwell and examine if the following are present:
X14260, pin 3, yellow-brown wire for right fog.
X14261, ping 37, yellow-brown wire for left fog.
I can't find any warnings about unplugging the footwell module, does anyone know if there are any consequences?
Old Feb 13, 2012 | 11:06 AM
ammodave's Avatar
ammodave
I can't answer your footwell module question but I can recommend that you don't remove your bumper just to check for fog light wiring. You can just remove the headlights and grill to gain access to the wiring if it's there. New fog lights can be installed without removing the bumper although it's a little tricky.
Old Feb 13, 2012 | 11:10 AM
Scooter09's Avatar
Scooter09
You can get to the foglights through the bottom opening in the wheel well... if that helps...
Old Feb 14, 2012 | 10:46 AM
schatzy62's Avatar
schatzy62
as Scooter09 said. to see if the wiring is there all you have to do is remove the round cover in the wheel well where you would change the bulb from.
Old Feb 15, 2012 | 04:06 AM
d@g's Avatar
d@g
Tried that, but didn't find anything promising. The way MINI tucked up the pre-wire for the rear fog (even some dealers couldn't find it), I didn't expect it to be dangling there waiting to be found. If it is there (and I've not heard of anyone who's found it), it is likely to be folded back and taped up in a place that's out of the way.
I don't think it's that difficult a task to pull the bumper skin. I figure I'll build the start of a harness first using a conventional H8/H11 connector. That way when I pull the bumper, I'll install the fogs and the wires will either be there, or not, but I can plug in and route the new harness and put the bumper back on. I know it's possible to remove the headlamps and access the foglight housing from above, but that may be just as much work and not provide enough access to search for any hidden wires. From what I've read, pulling the skin is perhaps a 20 minute job.
Old Feb 15, 2012 | 05:59 AM
SooperCuperErik's Avatar
SooperCuperErik
Sorry, small thread jack... Any idea if the headlights or parking light wires are on this connector as well? Do you have a diagram for that? It'd be a very nice and easy way to tap one of my gauges for dimming, as the dash lights don't provide the proper amperage to actuate the correct dimming on the gauge.
Old Feb 15, 2012 | 07:57 AM
SODA66's Avatar
SODA66
I am getting ready to replace my DRLs (do not have Fogs) with some Blinglights BL500K Fog and Driving lights with white angel eyes. I plan to do this today. I will probably just hook up the angel eyes to the factory wired DRL lights and then run the other light to the battery with a switch. Attached are some bumper removal instructions I got from someone else on this site.
I checked and could not find the document I attached. I do not know how to get it attached to this email link. I will send you a copy to your email address on the gallery link.
Doc Pain
Mar 10, 2021 04:50 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
GAT
Oct 4, 2015 07:27 PM
Sep 25, 2015 12:32 PM
