Electrical Help with PLX kiwi wifi - OBD port pin diagram
Old May 21, 2011 | 12:16 AM
remotecontrol's Avatar
remotecontrol
hello!
i just got my PLX wifi in the mail yesterday and found out i just couldnt get it connected with my Ipad Dashcommand.
I would get the wifi connected but not to the program.. i asked PLX and they said might be my OBD port pin is not "standard"...
I have a 2008 non-S cabrio and i found out in my car's obd port, only 1,4,5,7,8,9,16 is populated... i searched from the net and there is a BMW OBD pins that said:
1 +12V Ignition(in run or start)
4 CGNDChassis ground
5 SGNDSignal ground
7 ISO 9141-2 K-LINEengine (ISO-9141 and ISO-14230), automatic transmission diagnostic (in some models)
8 ISO 9141-2 K-LINE IKE/KOMBI, ABS, ABS/ASR, ABS/ABD, ESP, DSC, Airbag and other electronic equipment
9 TD/RPMEngine rotation speed
16 +12vBattery power
However i found in a diagram from other post where "standard" obd2 should have pins 2,10 (Bus +,-) 6,14 (Can high, low) and 7,15 (K,L line)?
which pins pair do i need to get gauge data or check fault codes actually?
Any ideas please and thanks in advance!
r
here is my obd port.
Flickr remote 's IMG00289-20110521-1109
Old May 25, 2011 | 06:35 PM
CORNERS's Avatar
CORNERS
I have a KiwiWifi and it works fine. Your problem is probably in communication between the Kiwi and your iPad. Reconfirm your wireless settings.
Old May 26, 2011 | 04:25 AM
NH_MCS's Avatar
NH_MCS
Ditto ^
PsychoRallye
21
Feb 17, 2019 06:08 AM
minimofo
Dec 26, 2015 12:03 PM
flpat73
Nov 2, 2015 06:38 PM
penguinplf
Oct 11, 2015 07:36 PM
TunedGP
Oct 1, 2015 04:18 PM
