Electrical Help needed - space behind dash
Old Jan 31, 2011 | 03:16 PM
tlr1000's Avatar
tlr1000
For those of you that have had your dash apart, can you tell me how much space is behind the dash panel indicated in red in the diagram below? I'd like to put a surface-mount switch there and the switch is 1¼" deep.
Old Jan 31, 2011 | 10:47 PM
Eric_Rowland's Avatar
Eric_Rowland
Can't say I've measured it, but just pull off the panel. Note 1): check to see if there is a screw on the lower right portion. Note 2) After pulling up the bottom portion, be sure to lift the top portion (two loops on the highest spots) over the tabs on the backing plate (don't just pull it off) and you can measure it for yourself. IIRC, I don't think that there's an 1 1/4" under there, but if you trim some of the supports on the trim piece, you might be able to find it.
I know someone has installed a V1 remote display on the left side of that panel.
Old Feb 1, 2011 | 06:53 PM
steelz21's Avatar
steelz21
Theres about 2 inches of styrophome back there, Just trim it back as much as you need for your switches. No problem.
Old Feb 12, 2011 | 01:55 PM
chris.j.lamb's Avatar
chris.j.lamb
it's EPP (expanded poly propolene) not styrophome btw.
Old Feb 12, 2011 | 04:10 PM
hunter99's Avatar
hunter99
The outboard edges right there are where MINI used to put the starter button accessory. Due to this there is room.
Old Feb 12, 2011 | 06:03 PM
tlr1000's Avatar
tlr1000
Ah, the answer I was looking for. Thx
Old May 15, 2011 | 10:26 PM
tlr1000's Avatar
tlr1000
here's the reason I asked about this: https://www.northamericanmotoring.co...146-post4.html
Thanks to all for helping me answer this question.
mishanja
Jun 22, 2016 09:59 AM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
kitty90034
Navigation and Audio
Aug 25, 2015 12:47 PM
Longjas
Aug 24, 2015 06:06 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
