Electrical V-1 is killing my dash!
Old Apr 22, 2010 | 07:16 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy)
Had it in the vehicle since delivery June '08. But in the hot sun, every once in a while, the suction cups give way and the damn thing dings my dash up! I've already got 3 small dimples where it dangled down and dinged it.
So....it's mounted driver side of rearview mirror, up very high, and works really well there, and I really want to leave it up there.
I've tried new suction cups, cleaning the glass and cups, etc. No luck. It stays up there 80%, but when it lets go, it dings the dash.
Has anyone come up with some sort of 'insurance' that would hold it up even if the suction cups let go?
Was thinking a spot of velcro, but really don't want to trash up things. Not sure where I could run a zip tie under it and connect above in the headliner, but figured someone else must have had this too.
Thoughts or suggestions?
Thanks.
Old Apr 22, 2010 | 07:25 PM
moodylewdd's Avatar
moodylewdd
I have mine in the exact same spot...but have a loop around the rear view mirror with the power cord. I am suspecting yours is the cordless one?
My suction cups are old, and do give up their holding power a couple times a year...but my low tech spit-on-the-finger seems to do the trick!
Old Apr 22, 2010 | 09:00 PM
Minidrivr's Avatar
Minidrivr
Use the visor clip instead of the suction cups and slide it above the headliner.
Old Apr 22, 2010 | 09:39 PM
onefish2's Avatar
onefish2
Been in my car in the same spot (above and to the left of the rear view mirror) for the past 16 months. No issue. Was in my prior car a 06 BMW 330xi in the same spot for 3 years, no issues.
Maybe you need to purchase new suction cups?
Old Apr 22, 2010 | 09:53 PM
minicooperwill's Avatar
minicooperwill
There's your answer. That location also makes it really easy for when/if you do the hardwiring (referenced elsewhere in these forums).
Old Apr 23, 2010 | 04:37 AM
cmcveay's Avatar
cmcveay
That's where mine is located and the suction cups did let go when the temps got down into single digits. When I put the power wire through the headliner, I ziptied it at the length I wanted. When it's not installed, I've got a 2" wire that I can't even see behind the mirror. When the suction cups let go, it just dangled.
Mine also rests slightly on the rearview mirror. I attached an adhesive backed rubber "foot" to prevent rattling. That seems to take some of the pressure off of the suction cups.
Because they aren't legal here, I also have a tint strip at the top of my windshield and that gives it a smooth surface for the suction cups.
Last, but not least, I've heard they will stick better if you apply rain-x to the inside of the windshield. Haven't tried it yet so I can't vouch for it personally.
Old May 5, 2010 | 12:53 PM
spinned's Avatar
spinned
Built a headliner bracket for mine.
Old May 5, 2010 | 01:31 PM
Motor On's Avatar
Motor On
x2, and regardless of hard wiring to the mirror or the fuse box it all tuck up there nice and easily, and keeps the nasty "rob this car" suction cup marks off the windshield.
Old May 5, 2010 | 02:25 PM
iwashmycar's Avatar
iwashmycar
i basically tucked the suction cup mount up in the headliner w/o the suction cups on it, then put a tiny bit of velcro on the top of the unit which pretty much sticks it to the headliner... hasnt moved a bit
Old May 20, 2010 | 02:43 PM
JENGLAND's Avatar
JENGLAND
I had a tint eyebrow added to my windshield just the thickness of the radar. This way it hides the V1 and is cooler for the cups. 1 1/2 years and no problems.
Old Jun 17, 2010 | 10:33 PM
Emann's Avatar
Emann
I've found that using a little bit of soapy water helps the suction cups stay on better.
Old Jul 8, 2010 | 01:52 AM
ArcticEd's Avatar
ArcticEd
The Blend Mount option supposedly isn't compatible with a Mini but I thought I'd post the link - maybe there's a similar product out there that is compatible or something that can be done to modify it:
http://www.blendmount.com/make.html
Old Sep 28, 2010 | 11:35 PM
robspec's Avatar
robspec
this is what i use to mount mine,i picked it up in person since they are close to me the owner of the company also owns a r53 mini,i have used them in other cars i have owned,ill try to post picks up of my install,quality of the prosuct is amazing
http://www.countryjoycrafts.com/350Z....htmAdjustable
Valentine-1 Z Mini Mount for 5/8 stem only,thats the specific mini one
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
