Electrical OBD wires + boost/volt gauges = no power?
Old Jan 8, 2010 | 08:57 PM
jollyroger927's Avatar
jollyroger927
So i went to re-wire all my gauges (prosport volt/boost/oil pressure/oil temp) because the connections were all bad. I cut, stripped, and then twisted together before being soldered together and taped closed. after reconnecting the harness to the gauges they didn't turn back on, and now my 12 volt constant wire on the obd port is cut and there is no power at all to that wire. I tested the wire and it wasnt showing any power at all. It doesnt make much sense to me.
Can the wire be dead? im not too good with electrical things but i did solder that wire so maybe i burnt it? I even cut where i soldered and tried to get power but couldnt. I ghetto rigged a wire from the cut obd harness wire, and the obd2 plug, then tried to read it and couldnt get a reading with my computer. Not even sure what that constant wire is for.
If anybody wants to help, the alta instructions show you which wire to go to for the constant 12volt.
Sorry if this makes no sense to some of you, im very agrivated with this mess and im still pissed with everything. Just hoping someone had this problem.
Old Jan 9, 2010 | 01:11 PM
jollyroger927
Anybody know what fuse is for that power wire? I replaced a couple last night im gonna go try it again, if it works ill post it.
Old Jan 10, 2010 | 11:16 AM
ALTA_Jarid's Avatar
ALTA_Jarid
What year is your car? I have an R53 manual at work and will try to help you tomorrow!!
Old Jan 10, 2010 | 12:51 PM
jollyroger927
05 cooper s thank you
Old Jan 11, 2010 | 01:29 AM
chris.j.lamb's Avatar
chris.j.lamb
Check F3 & F36
Old Jan 11, 2010 | 02:37 PM
jollyroger927
It turns out it was F3 (heated mirror). I changed the 2 burnt fuses i found that night except that one because i ran out of fuses and didnt think heated mirrors (which i dont have) would help haha.
Turns out i have power to that wire now, i'll let you know how it goes. Also should i put two gauges to that wire and the other two to another 12v source or all 4 to a different one? Which 12v constant would you guys use? Thanks alot chris!
triple5soul
21
Jul 29, 2016 04:27 AM
Chasp
Sep 4, 2015 09:31 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
Minii cooper bean
Aug 11, 2015 02:10 PM
