Electrical Always-hot 12v outlet?
Old Oct 28, 2009 | 09:33 AM
mjgrazi's Avatar
mjgrazi
Has anyone tried modifying the wiring to have a 12v outlet that stays on even when the car is off? I cannot bring a cell phone into the building at work, and routinely come out to a dead phone. Ignoring the 'turn it off during the day' solution (calls will go to dial-in VM rather than visual VM), I'd like to find a way to have power when the car is off. Is this a matter of just going to a different fuse, or would it novolve running a wire/fuse directly to a battery terminal, bypassing the fuse box?
Old Oct 28, 2009 | 10:23 AM
rkw's Avatar
rkw
Some of the fuses are always hot. Read this thread: https://www.northamericanmotoring.co...not-fuses.html
Old Oct 28, 2009 | 10:41 AM
lacning74's Avatar
lacning74
I wouldn't bother running directly to the battery.
Here's a neat solution someone did in a Saab with two Add-A-Circuits. Basically connected the cig adapter fuse to an always-on fuse. The "Hot or Not" sticky in the electrical forums lists which fuses are always-on.
Otherwise, you use the Add-A-Circuit to "hardwire" a new cig adapter like this and hide it in your glovebox or where-ever. This screw visible to the left of the glovebox when opened makes a good ground.
Don't forget to get the right size Add-A-Circuit depending on what fuse you use (mini vs regular size).
Old Oct 28, 2009 | 05:54 PM
Chimera's Avatar
Chimera
I just hard-wired a triple cigarette lighter using an add-a-circuit and by mistake the fuse I used was always hot (F21 in the 09 S fuse panel) instead of F23 (turns off after 30 minutes). So yes, it can be done
Old Dec 20, 2009 | 06:23 PM
luxmedic's Avatar
luxmedic
does doing this cause the battery to go dead after some time?
Old Dec 21, 2009 | 05:57 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Yes. If something is plugged into a hot socket while the car is off the battery will eventually drain. How fast depends on what is plugged in.
Rich
Old Dec 21, 2009 | 06:08 PM
luxmedic's Avatar
luxmedic
but if it is not plugged in everything is cool? is it possible to get a larger battery, something that will handle a lap top for a longer time?
thanks
Filmy
15
Jun 6, 2023 06:27 AM
1ZigZag
Oct 6, 2015 07:08 PM
Joeygonz
Oct 4, 2015 09:25 PM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
Puggles
Sep 11, 2015 11:53 AM
