Electrical Headlamp issue
Old Jan 26, 2009 | 11:18 AM
maximumini's Avatar
maximumini
Headlamp issue
I was wondering if someone can help me out. My driver side headlamp will only work in the high beam setting. One would think that by just replacing the light would solve the problem. Unfortunately i did this. Every light i put in only works when the high beam is on. It's like there's no power getting to it in the low setting. Mind you this is only the driver's side. So i don't think it's a fuse. Can someone help me out?
Old Jan 26, 2009 | 11:20 AM
glnr13's Avatar
glnr13
do you have xenons?
what year is your MINI?
Old Jan 26, 2009 | 11:28 AM
maximumini's Avatar
maximumini
I'm using Halogen lamps. I never had problems before. My Mini is a 2002
Old Feb 3, 2009 | 03:10 PM
Trilobite's Avatar
Trilobite
I'm having the same issue, only on the passenger side, but with regular lamps. I just picked up a bulb from a store, but couldn't figure out how to replace it. Any tips?
Old Feb 3, 2009 | 03:47 PM
UKSUV's Avatar
UKSUV
Did you check to see if a wire is broke??!?!
Old Feb 3, 2009 | 03:52 PM
Trilobite's Avatar
Trilobite
Hm, I didn't, but I'll make sure to check that when I get the hood up again.
Old Feb 4, 2009 | 03:23 PM
riggz's Avatar
riggz
I have no knowledge of Mini's as I am just a noob and learning but I know on other vehicles there are a couple relays for the headlights. Usually one for each side. Possible that this is the cause?
Old Feb 4, 2009 | 06:28 PM
Trilobite's Avatar
Trilobite
I just discovered what the issue was - the low beam light was out, which I didn't know about - looking at it the first time, I'd thought that there was only one bulb in there. *Embarrassed* Popped the new bulb in, it works great.
Old Feb 5, 2009 | 01:29 PM
comet5o4's Avatar
comet5o4
I don't have this problem... but in relation... I just changed out my blubs from the stock to super whites and now one of my headlights is lower than the other. I didn't think this was possible since the housing was pretty solid. I don't see any way to change the degree, and I've swaped the bulbs to see if it was that, but no. Am I just seeing things?
On a side note, I want to use my PIAA driving lamps all the time instead of hi-beams. what is the degree for that?
Old Feb 5, 2009 | 02:20 PM
quikmni's Avatar
quikmni
I suspect your bulb is not sitting properly in the headlight lens. The bulb might be turned a little bit so that it is not sitting in the indents correctly. You might be able to tell from the outside looking at the headlight (with the headlights off). Look closely at the bulb and see if it is sitting flush, no gaps, and not crooked.
Old Feb 5, 2009 | 03:56 PM
comet5o4's Avatar
comet5o4
Ok, I'll try that. thanx.
Old Feb 5, 2009 | 04:07 PM
UKSUV's Avatar
UKSUV
There are screws to adjust the headlights...all cars have them. Since not all headlights will sit exactly the same...
battlehawk_mini
Mar 5, 2021 06:15 AM
rtk90
Aug 29, 2019 09:08 AM
Mini Koopa
R55 :: Clubman Talk (2008+)
Sep 8, 2015 02:58 PM
tylewis
Sep 6, 2015 01:07 PM
Powershift
Aug 16, 2015 05:14 PM
