Electrical Replacing R56 Driving Light Bulbs
Old Dec 23, 2008 | 11:21 AM
scottab36's Avatar
scottab36
How do you get the R56 Driving light open to replace the bulbs?
I found a small slot at the bottom but I am not sure if this is used to open the light housing.
Old Dec 27, 2008 | 03:54 PM
Nimcosi's Avatar
Nimcosi
You pretty much need to remove them from their brackets, and there is small screw at the bottom of the light near the wire ingress that you need to remove. The lights then separate at the seam. Be sure to make note of the placement of the seals and wires for reassembly.
Old Dec 27, 2008 | 04:32 PM
scottab36's Avatar
scottab36
Thanks for the reply! I have a set of Silverstars that I want to put in to more closely match the HIDs!
Should look like a MINI UFO with that much light on the front.
Old Dec 31, 2008 | 10:38 AM
scottab36's Avatar
scottab36
So I get the lights all apart and there is a small tamper-proof torx bit screw in the middle holding the bulb in.
I guess I will be off to Sears this weekend for a new tool set...
Old Dec 31, 2008 | 12:47 PM
Minidrivr's Avatar
Minidrivr
Here's the install manual for the lights. Chapter 10 has info on replacing the bulbs in case anyone needs it.
Old Dec 31, 2008 | 04:29 PM
scottab36's Avatar
scottab36
Your the best! Thanks for the installation guide!!!
Old Nov 6, 2010 | 06:26 AM
jbourne's Avatar
jbourne
Hey,
Sorry to revive a dead thread.... but where did Minidrivr's attachment go? I need to replace mine, would have been uber useful.
Thanks!
Old Nov 6, 2010 | 08:07 AM
Minidrivr's Avatar
Minidrivr
Originally Posted by jbourne
Hey,
Thanks!
Not sure where it went but here you go.
File Type: pdf
Old Nov 6, 2010 | 08:17 AM
jbourne's Avatar
jbourne
Thanks very much
Old Jan 31, 2013 | 07:13 PM
nutsofamily's Avatar
nutsofamily
city bub removal
can you describe how you got the w5w bulb out in more detail?
Old Feb 10, 2013 | 07:19 PM
nutsofamily
Led no error then error
So I replaced my City lights with Led supposed error free.
Started car, no issues.
10 min later when starting car I get bulb error but it goes away.
I used the turn stalk to do "Sytem Check" and it states "All ok".
So my question is, is the bulb error correcting itself or not.
I don't care if it just shows up for 3 secs on car start up,
But, us the error still there?
Alkaidovich
Jan 30, 2021 01:35 AM
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
