Electrical Battery almost gone, should I replace with OEM?
Old Oct 3, 2008 | 03:26 PM
Mike S's Avatar
Mike S
Hi all,
I'm going to replace my battery pretty soon on my MCS - should I replace it with an OEM one as I see it has some funny stuff on the positive end or is it not really necessary and any car battery will do?
Old Oct 3, 2008 | 06:06 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by Mike S
Hi all,
If you can find an Optima Red Top 34R it is a direct replacement, better technology and higher capacity.
There are a bunch of threads that list some other replacements but frankly there is nothing better than the Optima.
Rich
Old Oct 4, 2008 | 12:12 AM
Mike S's Avatar
Mike S
Thanks, I've found a local supplier. Will give them a ring.
Old Oct 4, 2008 | 08:30 AM
UKSUV's Avatar
UKSUV
Rich
+1
Old Oct 5, 2008 | 11:15 PM
xnotfunkylex's Avatar
xnotfunkylex
I got mine at Costco.
Old Oct 6, 2008 | 05:37 AM
Mike S's Avatar
Mike S
Response to my email from local supplier:
"We have the Optima RTC 4.2L Red top @ ###### (Around $300 US)." A bit steep IMO - largely due to our import taxes.
Is that the right one, what is the average price of one in the US?
I phoned BMW, they are going to charge me $200 for a new OEM battery.
I don't have any big sound systems etc other than stock Cooper S sound.
Old Oct 7, 2008 | 10:04 PM
xnotfunkylex
I think I paid about $130 for my red top.
Old Oct 7, 2008 | 11:14 PM
Mike S's Avatar
Mike S
Holy I hate our taxes...
Will the battery he is mentioning be the right size for my car?
Old Oct 8, 2008 | 08:14 PM
Rich.Wolfson
...Will the battery he is mentioning be the right size for my car?
The 34r is a direct replacement. Perfect fit and you won't need the vent although I left it in there just in case. And it is 800AHrs which is more than the OEM battery.
I have no idea what a Optima RTC 4.2L Red Top is. I see no reference to it on the Optima site.
Rich
Old Oct 8, 2008 | 09:11 PM
ScottRiqui's Avatar
ScottRiqui
Actually, the Optima 34R is 800 Cold-Cranking Amps (CCA), not 800 Amp-hours. Its capacity is only 50 Amp-hours. (Both the capacity and cold-cranking amp ratings are higher than the stock battery, though).
An 800 Amp-hour battery would pretty much fill your hatch!
Old Oct 8, 2008 | 11:41 PM
Mike S's Avatar
Mike S
Rich
He would have to import the battery as that is the only Optima they stock here I might go the OEM route, bit too much hassle for just a battery as I have nothing other than stock sound in my car.
Thanks again for all your time and effort, you guys have been great
Old Oct 25, 2008 | 03:46 PM
AZblackOUT's Avatar
AZblackOUT
I highly suggest you reconsider to the Red Top Optima, depending on cost effectiveness ofcourse. Id say that going to a red top is worth 140% of what it would cost to do stock, if you can get a red top shipped in that price, do it. maybe costco online? not sure what they have to offer you in South Africa...
Costco also offers a 3 year no questions asked replacement on your battery...i shorted mine and upgraded to a yellow top because I run tons of sound and video, only cost me 20 bucks for the upgrade
Old Oct 25, 2008 | 04:13 PM
CHKMINI's Avatar
CHKMINI
+1 on the Optima. I bought mine at Batteries Plus.
Old Dec 25, 2008 | 11:21 AM
pyratio's Avatar
pyratio
Coordinator :: Hawaii MINI Motoring Club
+1 for Optima Yello
--I'm looking at an Optima Yellow Top D34/78. Going for $169 at Costco. I was surprised they had the yellows as they only carried reds before. I typically sit in my car and listen to the stereo with the engine off so I thought the yellow top would be better. Add to that I'm in the northeast where we've hit -10 degrees a few times already and winter has only just begun.
Anyone else have experience with this battery?
~p
Old Dec 25, 2008 | 12:43 PM
OldRick's Avatar
OldRick
I'd go with the red-top, as it is unlikely that you will run the battery down much unless you have a high-amperage aftermarket stereo.
BTW, while the Optima 34R is a perfect fit, you will need to shim it up about 1/2" to make the hold-down bar fit. You could either put something under the battery to raise it, or use a piece of wood about 1/2"x3/4"x6" to fit between the hold-down and the battery.
DO NOT just leave it sitting in there unsecured, as you wouldn't want to be in any accident where a forty pound battery came up and bounced around loose in the passenger compartment...
Old Dec 25, 2008 | 01:46 PM
mini_racer's Avatar
mini_racer
Thanks and nice tip on the fitment. I almost have 3 years on my OEM battery and so I guess I am much closer to the end of it's life than the beginning. The Optima red top sounds like a good selection.
Some here have also spoken highly of the Braille battery, which is a much smaller option. I think it is only 11 lbs, significantly smaller, I would expect less CCA and even more fitment issues than the Optima.
Old Dec 25, 2008 | 08:19 PM
OldRick's Avatar
OldRick
The Braille battery is also about half the capacity. Lower weight is nice, except that the MINI already has a strong front-wheel weight bias. And don't plan to use one in snow country.
But if you do use a mini-battery, you can remove the battery box and get a straight-through exhaust.
All of life is a series of engineering trade-offs...
stevepsd
35
Dec 6, 2022 03:22 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
jeremy_reyes94
Aug 12, 2015 10:56 AM
