Electrical Lower grill light bar question
Old May 19, 2008 | 08:42 AM
Sin MINI's Avatar
Sin MINI
I have an Alta light bar and plan to install the lights here soon, but I have a question. Once the lights are installed, I see removing the bumper cover to be difficult if not impossible unless the lighting harness has some type of disconnect behind the bumper cover.
What have folks here done that have installed lights in the lower grill?
Thanks!
Old May 19, 2008 | 08:47 AM
Gil-galad's Avatar
Gil-galad
You're in luck. The Alta wiring harness has connectors that are relatively close to the IPF lights (maybe 8" upstream from the mount). To remove the bumper cover, it would be a relatively simple task to unplug the lights and remove the bar first.
Old May 19, 2008 | 10:15 AM
Sin MINI's Avatar
Sin MINI
I hadn't even noticed...thanks for pointing that out.
Old May 25, 2008 | 06:09 PM
Sin MINI's Avatar
Sin MINI
Upon further review...I thought those were crimp connectors. I assume then these are just pop-in connectors and can be disconnected without damage?
Old May 26, 2008 | 07:59 AM
Gil-galad's Avatar
Gil-galad
Yep...just pop-ins. They're pretty snug, well shielded from the elements, and no need to crimp them (unless the harness you received is different than mine).
Old May 26, 2008 | 09:10 AM
Sin MINI's Avatar
Sin MINI
Wow...that saved me a whole lot of extra work. For those wondering what lights to buy, the IPF harness is SO much better than the Hella one I took back.
minipopkart
Aug 13, 2015 05:22 AM
Aug 7, 2015 05:56 AM
OutMotoring
Aug 6, 2015 09:32 AM
