Electrical Failed MCS O2 Sensor
Old Apr 16, 2008 | 06:51 PM
Mini7's Avatar
Mini7
I am looking for two failed O2 sensors. What I am after is the harness and female plug.
I have managed to find the male part of the plug on REAL OEM. I have also tracked down the 4 wire with the female crimp on terminals which fit into the 4-wire male plug.
What I cannot find is the male flat pin terminals which go into the female part of the plug which is on the O2 sensor harness side.
Does anyone know where I can source these parts. I beleive that it is an AMP connector.
I have tried the dealer and they did not think that these items were seviceable which relly sucks.
I hope that some of you DIY'ers are smarter than me.
Old Apr 17, 2008 | 09:08 PM
Mini7's Avatar
Mini7
Help needed finding male electriacl terminal pin...
Does anyone know where I can source the flat male pin that will fit with this female terminal connector (P/N#12520007172)?
No. Description Supplement Qty From Up To Part Number Price Notes 01BUCHSENKONTAKT SLK 2,8 MIT KABEL0,5-1,0 MM?12520007171$1.5301BUCHSENKONTAKT SLK 2,8 MIT KABEL0,25-0,5MM?1252014095902SOCKET TERMINAL SLK 2.8 ELA WITH WIRE0,2- 0,5MM?12520007170$1.5302SOCKET TERMINAL SLK 2.8 ELA WITH WIRE0,5- 1,0 MM?12520007172$1.5303FLACHFEDERKONTAKT MICROTIMER MIT KABEL0,5 MM?12520007251$1.1204FLACHFEDERKONTAKT MDK4 2.8 MIT KABEL2,5 MM?12520007253$1.1204FLACHFEDERKONTAKT MDK4 2.8 MIT KABEL0,5 MM?12520007254$1.5304FLACHFEDERKONTAKT MDK4 2.8 MIT KABEL1,0 MM?12520007255$1.7704FLACHFEDERKONTAKT MDK4 2.8 MIT KABEL1,0 MM?12520141125
Old Apr 17, 2008 | 09:09 PM
Mini7's Avatar
Mini7
That cut and paste did not work out to good
Old Apr 17, 2008 | 09:11 PM
Mini7's Avatar
Mini7
Here is the link to the REALOEM page: http://www.realoem.com/bmw/showparts...50&hg=12&fg=32
Hope this works....
iggi
18
Feb 9, 2026 01:00 AM
Kimolaoha
Jul 5, 2023 01:04 PM
HaveATank
Sep 4, 2015 08:04 AM
PrimePower
Aug 16, 2015 06:29 PM
massmini03
Aug 12, 2015 11:19 AM
