Electrical switch install question
Old Dec 3, 2007 | 02:59 PM
midMOmini's Avatar
midMOmini
i installed a set of driving lights on a light bar and now have a question. i have another switch panel here with the swithces in and i am wanting to install it into the empty spot of my stock panel. i dont know which pins or wires to tap in to to hook my wires up for the switch. any help would be appriciated.
Old Dec 4, 2007 | 09:18 AM
Eric_Rowland's Avatar
Eric_Rowland
The OEM toggle panel sends signals to the BC1, which does the actual switching. To make your setup work, you'll need to intercept the signal and send it to a circuit which will switch the lights on.
You can try PMing Ian Cull - GBMINI - and see if he can help you out. He does a custom 'Auto Up Circuit', which can be adapted to other uses (mine opens the garage door.)
Old Dec 5, 2007 | 07:54 PM
MaxMini81's Avatar
MaxMini81
Wanderer
My toggle panel has seemingly come loose. The toggle switches, esp. the window ones, do not open the windows/actuate their devices unless i reach beneath the unit and support it with my fingertips as I depress the switches. Is there a way to tighten the panel or fix this? Have any of you experienced something like this? Please help me out if possible.
Thanks,
Chris
silence2-38554
Nov 12, 2015 09:39 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
squawSkiBum
Oct 2, 2015 09:21 AM
