Electrical Invisicord in Radar Detector Install?
Old Nov 28, 2007 | 08:58 AM
jmdor's Avatar
jmdor
Has anyone used the invisicord (www.invisicord.com) to install a V1 or escort in their R56?
Old Nov 28, 2007 | 09:35 AM
lacning74's Avatar
lacning74
The Inviscord would not work well with the rear view mirror itself. There is not an easily exposed harness to simply plug into. Here is a DIY hardwire to the headliner above the rear view mirror.
For my hardwire of an Escort 9500i with SmartCord remote, I used an Add-A-Circuit (mini size) to the fusebox F32 and tucked the wiring between the headliner and windshield and down the passenger side outside edge A-pillar under the door gasket strip. There are lots of crevices to hide wires. Takes less than 10 minutes and is just as stealthy.
If you are using a remote display/mute button, this would be a better option because you need to run wire anyway to the radar detector.
I also hardwired my NUVI GPS in similar fashion.
Old Nov 28, 2007 | 10:15 AM
Minidrivr's Avatar
Minidrivr
It's easier to run the wire to the fuse box than to try to splice that invisicord thing in. Don't even have to remove any dash/trim pieces. An add-a-fuse keeps you from having to splice anything too.
Old Nov 28, 2007 | 11:51 AM
jmdor's Avatar
jmdor
Very interesting -- when you talk about the lighter plug, was that an interim solution before you went to the add-a-fuse? It seems like you wouldn't need a lighter plug with the add-a-fuse. Also, the add-a-fuse doesn't have a ground? You have to ground separately?
Thanks! You've been great help!
Old Nov 28, 2007 | 12:11 PM
Minidrivr's Avatar
Minidrivr
The add-a-fuse just adds power, 12v, you still need a ground. The screw that is visible inside the glovebox works fine for this. If you use a lighter plug, it would be powered and grounded through the lighter socket.
Old Dec 1, 2007 | 02:44 PM
lacning74's Avatar
lacning74
I used a separate cigarette lighter female plug adapter for my Garmin Nuvi since the traffic receiver is built in the cigarette lighter plug. I still connected the wiring of the adapter to the add-a-circuit and grounded it to the screw visible inside the glovebox as mentioned by Minidrivr.
As for my radar detector, I didn't use a cig female adapter. I directly wired it to the add-a-circuit and grounded it in similar fashion. I then mounted the Escort SmartCord remote in the top-left of the center cubby with double sided tape. Easy to reach there.
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
siriuszero
Sep 17, 2015 04:41 AM
minimofo
Sep 9, 2015 10:29 AM
