Electrical Splitfire: torque rose with large popularity!
Old Sep 9, 2007 | 11:02 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
This is from a japanse tuning site: splitfire <<this takes you to the main page...
thier site used flash or something, the text is in the next post
This system is supposed to boost electrical efficiency leading to increased torque, throttle response, idle smoothness, fuel economy, and make your headlights brighter.
I dont see how a bunch of wires connected at random bolts could possibly do what they claim. Has anyone seen a system like this elsewhere or tried something similar? You could even get a bunch of your own wire and do it, they show you where to hook it up.
here are some of the images
nabeshin's Avatar
nabeshin
Functioning Lunatic
that link didnt work...
here is the text from the translated version:
[FONT=MS UI Gothic][SIZE=2]Since selling, “torque rose with large popularity!”With it is the commodity of extolment.[/SIZE][/FONT]
[FONT=MS UI Gothic][SIZE=2]0 power source which is utilized in the automobile for simplifying wiring, minds [podei] usually and is connected to 0 terminal of the battery. But, as for this method when you think from the efficiency aspect, it is efficiency not to be able to say excessively. The body material most because of the steel sheet, produces very high resistance in comparison with the copper and the like which is used for wiring and the like, the difference is to reach also 10 times or more. It is this resistance to obstruct the smooth flow of electric current, to cause substantial performance down. Furthermore, as for this efficiency decrease it is to be the big problem which it should solve regardless of the new model and the advanced age type car. It is the electrical type tune-up part which actualizes numerous performance rise by the fact that the split fire strengthens the genuine ground system, makes the flow of 0 power source smooth.[/SIZE][/FONT]
[FONT=MS UI Gothic][SIZE=2]As for this product it produced with One, Cooper and Cooper-S combined use. Only in case of Cooper-S, like the below-mentioned picture the rear battery - directly [a] - [su] it does in the empty body. You install the rear battery - to [ha] - [nesuko] - without pulling [do] from the central block part which is inside the front bonnet. The central block hippopotamus - and [separe] - [ta] - and the like, the excessive pas - deleting [tsu], from the usual SplitFier product it succeeded in the rollback [patsuke] - by [ji] doing. You install of course and also the instruction manual has belonged. Also installation being simple special processing and the like without necessity, it is effective [batsugun]. In order to be easy to coordinate with the hot wire, also the lead harness added sold. When [tsuinkoa] [puraguko] - you install with [do] and set, it is Good-Feeling![/SIZE][/FONT]
[FONT=MS UI Gothic][SIZE=2]- Improvement of the torque in the low and medium-speed limits.[/SIZE][/FONT]
[FONT=MS UI Gothic][SIZE=2]- Improvement of the throttle response in the entire area.[/SIZE][/FONT]
[FONT=MS UI Gothic][SIZE=2]- Stabilization of engine high rotary limits.[/SIZE][/FONT]
[FONT=MS UI Gothic][SIZE=2]- To begin and kinesis to improve, stability of idling.[/SIZE][/FONT]
[FONT=MS UI Gothic][SIZE=2]- The fuel economy improvement with combustion efficiency rise.[/SIZE][/FONT]
[FONT=MS UI Gothic][SIZE=2]- Purification of exhaust. (Decrease of HC/CO density)[/SIZE][/FONT]
[FONT=MS UI Gothic][SIZE=2]- Luminous intensity rise of headlight[/SIZE][/FONT]
[FONT=MS UI Gothic][SIZE=2]- Sound quality improvement of audio. (Decrease of various noises)[/SIZE][/FONT]
Old Sep 9, 2007 | 11:15 PM
ScottRiqui's Avatar
ScottRiqui
The only way this would make a difference would be if the factory ground straps were loose, missing, or so worn/corroded that you started having voltage drops, electrical noise and other problems. And in that case, you're better off cleaning or replacing the factory connections than spending close to $150 for what amounts to nothing more than a few lengths of wire and a ground distribution block.
Old Sep 9, 2007 | 11:41 PM
Dr Obnxs's Avatar
Dr Obnxs
There are some cars with bad grounding schemes.
or cars hacked up by bad tuners where this could help. Don't think it's worth anything on a Mini.
Matt
think about it. If a heavy ground strap made power, there are some engineers who need to be fired!
Old Sep 9, 2007 | 11:51 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I does seem more likely it's bupkis.
carid
Dec 28, 2025 04:11 AM
techgearpro
Jul 23, 2019 07:09 PM
R3411y
Nov 23, 2015 01:10 PM
Sep 10, 2015 10:52 AM
cw40342
Sep 2, 2015 06:01 AM
