Electrical Retrofit PDC?
Old Jul 28, 2007 | 10:50 AM
familiarstranger's Avatar
familiarstranger
Retrofit PDC?
while we are on the topic of retrofitting how feasable would it be to retrofit the PDC including the hookups to the NAV?
Bryan
Old Aug 1, 2007 | 09:35 AM
diablito's Avatar
diablito
I have seen a retrofit which goes on either side of the lic plate. Warning is audible as well.
I hope this helps.
Bryan
Old Aug 1, 2007 | 10:22 AM
familiarstranger
thanks diablito, i am looking into configuring it with the NAV. more of a theoretcial now than anything else. I got more concrete mods to work on. thanks for the input!
Old Jan 4, 2009 | 08:10 PM
damagi's Avatar
damagi
I'm interested in this as well. Clearly this is an old thread, just curious if anyone has done it.
http://www.realoem.com/bmw/showparts...27&hg=66&fg=95
That seems to indicate that the "PDC Install Kit" should be able to be obtained somehow. My other thought was to see if I could get a PDC kit from a salvage yard mini and retrofit it.
Also - anyone know if the PDC hooks into the IBus? I am considering doing a CarPC setup and it would be great to get the info off of the IBus and end up with similar visuals to what you get if I had the NAV option.
Old Jan 4, 2009 | 09:42 PM
rkw's Avatar
rkw
It hooks into the CAN bus. IBus was in the 1st gen MINI; R56 uses CAN and MOST busses (some of it is fiber optic).
Old Jan 5, 2009 | 12:28 AM
Minidrivr's Avatar
Minidrivr
A couple dealers I've emailed have said it's not possible to add it at the dealer. But that price of that kit isn't too bad. Even if you self installed it, you'd still have to take it to the dealer to have the computer reprogrammed so it knows it's there.
Old Jan 5, 2009 | 06:01 AM
schatzy62's Avatar
schatzy62
The problem with the kit as i see it is that it does not include the new bumper that would be required to be used to install the kit.
I believe that the sensors can not be fitted to a "non PDC" bumper. This is probably why dealers will not do it. Just to expensive once the bumper is added to the cost.
Old Jan 5, 2009 | 09:25 AM
rkw's Avatar
rkw
In R56, PDC sensors are not in the bumper itself as they were in the 1st gen MINI. They are in the bottom black trim (at least for non aero kit).
Old Jan 5, 2009 | 10:36 AM
Minidrivr's Avatar
Minidrivr
And that piece is easily replaceable. At delivery my Mini had a 3-4 scratch in the lower black trim. They replaced that piece so it is separate from the bumper.
Old Jan 6, 2009 | 08:41 AM
zoltiz's Avatar
zoltiz
Do we have a reliable/reasonable OEM parts supplier here? If there is a PDC Install kit, then it should definitely be "retrofittable".
I'll get in touch with my dealer's parts dept, but from my experience you have to be extremely lucky to get a dealer who's willing to work with DIY aficionados...
Old Jan 18, 2010 | 04:46 PM
radgator1's Avatar
radgator1
Update please
So has anyone done this on a Clubman yet? I have a clubman with Nav but no PDC coming by next week and I really want to add this. There are aftermarket systems available but I would love to be able to add OEM integrated with the screen if it is possible and not cost prohibitive.
Thanks, Kevin
GregoryK
Dec 14, 2015 01:34 PM
ducanero
Navigation/Audio
Oct 12, 2015 01:13 AM
ahorvath
Oct 3, 2015 01:13 AM
bbak11010
Sep 7, 2015 08:08 PM
bbak11010
Sep 7, 2015 08:03 PM
