Electrical Back-up Camera Wiring
Old Jan 10, 2008 | 06:04 PM
  #26
Minidrivr's Avatar
Minidrivr
Originally Posted by lacning74
I'm thinking of wiring a wireless camera to the license plate lights instead. Anyone know which color wires to use? A bundle exits the boot handle. One set must be the latch release and the other the lights.
You realize it will only work when your plate lights are turned on right? If you use daytime running lights it would work I suppose.
Old Jan 10, 2008 | 06:44 PM
  #27
lacning74's Avatar
lacning74
I do use DRLs. I was thinking to turn the monitor on or off when I needed it. The monitor apparently randomly flickers with stray security camera signals when the camera is not powered. It would be easier to install as well due to proximity. There would also be no delay for the camera and wireless signal to work.
I could also run the camera wire to an ignition constant on source, but if I'm doing that, I should have gotten a wired camera.
Of course, the camera could burst into flames after a long road trip.
Old Jan 10, 2008 | 10:17 PM
  #28
Minidrivr's Avatar
Minidrivr
You could find a wire in the dash that would switch on the monitor when you put the car in reverse. I did this on my truck. Most stereo shops can look up the wiring charts and tell you where to tap into. I wired the camera into the reverse lights, and the monitor hooked up behind the dash, on the same signal that goes to the back of the truck to turn on the reverse lights. They turn on together this way.
You are right, with the monitor on all the time it picks up all kinds of interference and even some security cameras.
Old Jan 11, 2008 | 08:51 AM
  #29
lacning74's Avatar
lacning74
Thanks Minidrivr. I'm going to try that. Anyone know where to look in the front for the wires? I guess by the fuse box. oPossum's diagram shows a footwell module.
Old Jan 19, 2008 | 05:35 PM
  #30
lacning74's Avatar
lacning74
Just installed my wireless back-up camera. I'll post pictures and details later, but one thing is bugging me.
The picture is pretty clear except for a constant 4 lines of interference that appears after a second or so of image once I shift into reverse. I tapped the reverse light wires. Interestingly, they go away when I actively turn the steering wheel. Guess turning the wheel draws power in the system and does something to lessen the interference. Maybe it strengthens the camera's wireless transmission? Or maybe it decreases the video receiver's interference?
It would be nice if there was a way to keep the image clear. Moving the monitor closer to the camera interestingly does not improve the image.
Any thoughts?
Old Jan 20, 2008 | 07:33 AM
  #31
lacning74's Avatar
lacning74
Any thoughts?
Update. There is no interference when the engine is off (I just pressed the start button without depressing the brake pedal in my automatic). Guess it's some interference caused by the running engine. I think I'll try moving my add-a-circuit to another fuse.
Old Jan 22, 2008 | 03:34 PM
  #32
lacning74's Avatar
lacning74
After looking into "alternator noise" and "noise filters" and trying different grounding points, I just tried running the camera power line to the fusebox. No more constant 4 horizontal lines of interference when the engine is on! Guess the right reverse lamp power wire gets too much noise interference from the engine/alternator/fuel pump/who knows?
So much for wireless camera, though, since I ran the wire up to the front anyway.
Old Jan 24, 2008 | 03:35 AM
  #33
ghosthound's Avatar
ghosthound
how bout pix of the install!
Old Jan 24, 2008 | 08:52 AM
  #34
lacning74's Avatar
lacning74
Here you go.
OutMotoring
Mar 3, 2017 06:29 AM
SJ-R50
Oct 28, 2015 08:39 AM
FatherG
Sep 29, 2015 02:47 PM
ericf1993
Sep 26, 2015 03:58 PM
dragonby
Sep 25, 2015 08:10 PM
