Eastern Iowa MINIs Eastern Iowa MINI enthusiasts group
R50 crankshaft pulley
Old Aug 21, 2014 | 03:05 PM
Englishgrnr50's Avatar
Englishgrnr50
So my r50 is having a pretty normal issue with the stock crank pulley going out/ becoming unbalanced. I have read that the oem part is likely to go out fairly quickly too. Outmotoring has an aftermarket pulley which is much cheaper, however my local iowa city mechanic is not willing to install it. Anyone with experience in this area or has any advice would be awesome. Thanks
Old Aug 21, 2014 | 03:48 PM
minsanity's Avatar
minsanity
The PRW fluid damper 2510901 is for the R50. 2510900 for the R53. Don't get a solid pulley. Check it on Amazon. Get a new OE crank bolt when swapping. Use a crow-foot pulley puller to get your old 1 out. You need to heat the new pulley for easy install. Search for the ATI Super Damper install instructions. I can't remember the ATI part number for the R50, but for the 53, it's 917992.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
Supertractor3
Apr 7, 2017 11:16 AM
Sep 10, 2015 01:48 PM
Sep 10, 2015 10:52 AM
