Sounds interesting,(actually I don't know what it is) maybe we could have a forum
https://www.northamericanmotoring.co...-yourself.html
Send a PM to sdbryant -- I know he's experimented with it.
JPMM, I sent you a message with a list of the items I have changed.
Programmed:
1 touch tilt, open, and close of the sunroof - holding the switch is a pain
Doors unlock when removing the key from the ignition.
Digital speed always shows on the tach display as you cycle through all the options, I think the 2011's are set this way.
Opening doors will not interupt windows rolling up.
Double blink hazard lights, something different.
Fogs and hi-beams on simultaneously.
A/C does not come on automatically with the Auto climate control.
Programmed:
You need to request access from GTECKO, just PM him asking for access to the NCSExpert spreadsheet. He will respond. Then you can use this link to access the sheet. The first post in this link explains it.
think you could program the OEM driving lights I just had installed to stay on when I want them too?
How about the OEM lower fogs too?
Quote:
Programmed:
Originally Posted by sdbryant
JPMM, I sent you a message with a list of the items I have changed.Programmed:
I know we could make the fogs stay on with the brights, not sure about the driving lights. Is that what you were thinking?
