Mini Cooper Cylinder Head Refurbished R50 R52 R53
Old Oct 27, 2015 | 11:15 AM
Mini Mania's Avatar
Part No: NME6006
SALE Price $1195.00
Was: $1,295.00
You save: $100.00
This is a Special Priced Item
This Item has a $300.00 core charge.
Fits the following models:
2002-2006 R53 Cooper and Cooper S Hatchback
2005-2008 R52 Cooper and Cooper S Convertible
Stock Cylinder Head that has been refurbished - a cost effective way to replace your 'tired' cylinder head. If you have a high mileage head with worn valve guides, bad seats, or burnt valves, this replacement is the solution. These are Cooper S heads, but can be used on both Cooper and Cooper S models.
These are NOT just 'cleaned up' used heads. They are thoroughly inspected and tested and everything is brought back to spec with a full valve job. This includes:
  • Thorough cleaning to start
  • Pressure tested (at high pressure) for leaks or cracks
  • All new valve seals
  • Re-cut valves and seats
  • New guides where needed (most are usually replaced)
  • Re-surfaced to spec
AoxoMoxoA
19
Nov 5, 2015 01:30 PM
odieman23
Oct 11, 2015 11:30 PM
simo711
Oct 8, 2015 07:07 PM
twriter
Oct 2, 2015 07:09 PM
Emnotek
Oct 2, 2015 08:43 AM
