ALTA Performance Feedback! (questions/comments)
#176
Lol, you are far from the "99%" range my friend. Once again, if you didn't like the fit as you were installing it, why did you? That is like having a size 11 foot and buying a size 9 shoe because they didn't have your size.
Whatever.... Still sounds to me that it all falls on how you installed the products.
#177
#178
#179
OK, I'll bite (as usual).... Ummm I Google what you said and there wasn't anything even on the FIRST page of the results that was linked to Alta and MINI's.
As for the BBB, they are a joke and most people know this. They are NOT a gov entity but rather a charity driven entity that doesn't work and a company is not required to deal with them. On their site, Alta had a whopping 8 (out of THOUSANDS of sales) complaints... They are rated at an F because the company failed to respond to the BBB, not the customer so I fail, once again, to see where your arguments are just. It seems to me that you simply like to bash the company because you didn't get your way. Kind of pathetic actually.
I want to say this for everyone else to read. As of late it may seem that I am cheerleading for Alta. To a point, yes, I have but there is a reason. I have no problems with people going after a company but it needs and should be for the right reasons and using common sense. Does Alta get it right every time? No, they are human, but I do think that they at least make an effort and that counts. Customers like the one above will simply complain for the sake of complaining. Frankly if he didn't want codes tossed he shouldn't have modded his car. It is a risk that we take when we move something from a baseline.
#181
Not too sure what the issue is here, can you give us a bit more info? Is the pulley new or been on for a while? What year is your car and is it a Cooper or S? I wouldn't think the pulley would put marks on the outside of the belt as the pulley touches the inside of the belt. Any pictures of the marks?
#182
#184
I took this picture today I'll try to get clear one ASAP
http://farm5.static.flickr.com/4013/...29f03778_o.jpg
#187
#188
on
I guess I've been pretty fortunate! The only problem I've had with Alta is my somehow my shipping address always gets messed up. Other than that, everything I've ordered has been as described (garage sale/clearance/new). I've purchased directly from them and through their vendors. Everything has been perfect. My stubby antenna, 15% pulley, dr12s plugs, tensioner stop, and my latest purchase, is the last alta light bar that I magically found on their facebook fan page at the most perfect timing. Alta has been more than helpful on several occasions for me, and has even helped my mechanic (it was his first time installing a pulley on a mini and asked what the average charge was... and PS you should have said LESS!!!!). Thank you Alta
Justin
Justin
#191
#192
Justin
Justin
#194
#195
#196
#197
#198
on
Again, both should be resolved today, tomorrow or wednesday. Thanks again!
I've installed H&R springs, sway bar and links.
Outmotoring suggested to install rear links in both front an rear, so I did now I have a clanking noise in front when I hit any rough bumps most of the time while I hear nothing if the bumps are small.
What do you think guys?
Have a GREAT February everyone!
#200
I bought the FMIC used so I can't comment on customer service or any aspects of the ordering, paying, etc. However, what I can comment on is the product itself. I installed it myself and the breakdown and removal of the stock intercooler is simple. When I tried to place the Alta IC I noticed that it dosen't fit. I'm not talking about some of the cuttng that's involved(which there is and if I didn't on a dremel I would have had a harder time) but the connection on the passenger side is at an angle and the IC wasn't. I was wondering why they didn't make it with the correct angle so that the install is smoother and not have to try and cram the intercooler hard enough to get the hoses to reach enough to clamp down the hoses securely enough not to worry about them popping off. I bought the IC for $300 and plan on selling it and geting one that fits correctly.
Performance is good and can really feel a difference above 3K rpms. Buri worry more than I like about one of the hoses popping off.
