RMW Solution to High Inlet temps......
Old Oct 14, 2008 | 06:44 AM
Revolution Mini Works's Avatar
As many of you know we have been working on getting the most consistent inlet temps to make the most reliable and safe power. Having tested air to air and water to air and older style meth systems, nothing really made me 100% happy. Now after having a meth kit made which controls our system much differently than other systems, we are ready to release it. The problem we found with the other meth kits is they killed the mid-range power by overspraying. This kit delivers just the right amount of meth at the proper time.
This kit is 100% ready to go. We have our own special jettings and settings ready for the end user to make it as seamless as possible. Sub ambient temps are just an install away
We have seen the car dial in 6-8 degrees more final timing due to lower inlet temps. More timing means more power! There are many factors involved in getting the timing and air/fuel ratios correct and how the ECU reacts to these factors.
File Type: pdf
File Type: pdf
Old Oct 14, 2008 | 06:57 AM
ca$per's Avatar
ca$per
nice
Old Oct 14, 2008 | 07:02 AM
fullcollapse40's Avatar
fullcollapse40
Incredible! Is part throttle driveability affected at all ?
Old Oct 14, 2008 | 07:03 AM
UnsanePyro's Avatar
UnsanePyro
Good stuff. Whats the word on pricing and install time?
Old Oct 14, 2008 | 07:17 AM
Bigshot's Avatar
Bigshot
How "automatic" is this?
Old Oct 14, 2008 | 07:23 AM
not at all
it's all in the designed system. This was part of the problem before with the older style kits.
We are working on a very fast install way. Pictures should be up in the next few days. Pricing with the quick install kit will be around $1,000
Once you get it initially installed, just fill it with water/meth and start your car
Old Oct 14, 2008 | 07:31 AM
jhiggs26's Avatar
jhiggs26
I think most meth/water injection systems are based on WOT. I'll let the pros answer you on that one. Personally I wouldn't want to waste meth solution(consumable) on part throttle Sunday driving.
Can RMW show us the kit and pricing please.
Jeremy
Old Oct 14, 2008 | 07:32 AM
Bigshot's Avatar
Bigshot
So this system runs all the time?
How long does the water/meth supply last under daily driving conditions?
Or is it simply triggered by throttle application?
Old Oct 14, 2008 | 07:36 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Stop making all your good stuff so expensive.
Old Oct 14, 2008 | 07:38 AM
PRattenbury's Avatar
PRattenbury
I'd be curious about consumption of spray as well. Not to mention, since water is incompressible, what is happening to cylinder pressures?
Old Oct 14, 2008 | 07:57 AM
Jeremy
this one can be based on part throttle too...........you get to pick where and when you want it..... (this is why it works so much better through the mid-range) We will have pictures.... it's going to be a few days.
no it runs only when YOU want it, we will give you guideline settings but you can tailor it to your driving. If you are out for a Sunday drive and don't even want it you can easily turn it off. It lasts much longer than you think even with spraying it most of the time.
Well........you could spend $2000-3000 for a W2a and still not get these temps
We used straight methanol in the above graphs. We will release more of the data as we go along. Problem now is trying to get enough kits to satisfy all of the orders
We have them on race cars and will be reporting some findings back end of month.
Old Oct 14, 2008 | 08:03 AM
Bigshot's Avatar
Bigshot
Old Oct 14, 2008 | 08:07 AM
fullcollapse40
I had been debating pulling the trigger on one of the coolingmist kits, but now I am glad I didnt.
Are you planning on tuning cars to run this system, or just using it as a supplement ?
Old Oct 14, 2008 | 08:13 AM
PRattenbury
Methanol burns at a different rate than gasoline. Does the introduction of methanol require variation in timing and fueling to optimize the burn? Do the methanol and fuel become a homogenous mix in the combustion chamber?
Old Oct 14, 2008 | 08:22 AM
we have so far just been running them on top of the stock RMW tunes but for those that are serious we can tune to this
yes it is mixed into the system in the intake manifold, we are logging the timing along with everything else. We are seeing much more timing run on hot days with this vs no meth. Typically about 6-8deg more
Old Oct 14, 2008 | 08:33 AM
fullcollapse40
oh baby ! I'll give you a call tomorrow then to place my order.
Francis
Old Oct 14, 2008 | 02:13 PM
batrugger's Avatar
batrugger
The real benefit here is the cooling effect, but water/ meth can emulate 100 octane gas so if you tune for it, you will get an even bigger increase in performance by having the increased timing. The problem with tuning for the meth though is that you will always have to spray it. Now those great MINI ECUs will do a little compensating for the higher otane too.
Old Oct 14, 2008 | 02:31 PM
just think what Kelli's will do with this kit on the track?
Old Oct 14, 2008 | 02:34 PM
poskey's Avatar
poskey
Jan, can you help those of use who already have W/M injection but are still experimenting? I have a coolingmist progressive system. Can I use your nozzles? What size are you using? I'm using a 90cc per minute right now and it has certainly helped with the pinging but hasn't cured it completely. I have a 180cc per minute on order and it should be here any day. You are going to tune my mini on friday in Dallas. Think you can help me/us with this? Thanks
Old Oct 14, 2008 | 03:09 PM
D-MAN's Avatar
D-MAN
Just a few questions
1. Are you using single or multiple jets?
2. By running straight meth aren't you going to reduce the life of the pump as opposed to running a 50/50 mix? Or are the pumps modified? I realise it is trade off between the mix and power.
3. Does the kit come with a fuel cell?
4. Are stainless hoses an option?
Old Oct 14, 2008 | 03:10 PM
fullcollapse40
oops, nvm
Old Oct 14, 2008 | 03:12 PM
fullcollapse40
Rather than asking the magician to explain on a public forum how he performs his tricks, you might try just calling him.
Old Oct 14, 2008 | 04:11 PM
poskey's Avatar
poskey
Yeah, I will be seeing him on friday. For those of us that have W/M systems, I'll see if I can get Jan to give away some secrets and we can all benefit.
Old Oct 14, 2008 | 04:26 PM
I like you Frances!
Old Oct 14, 2008 | 04:27 PM
gnatster's Avatar
gnatster
Maybe Jan can bring one out to show us. I'll be happy to track test it on Sunday too....
