Drivetrain Mini Madness Oil Cooler and Unichip Version Q
Old Apr 17, 2007 | 05:29 PM
scolburn79's Avatar
scolburn79
Hey,
Just getting peoples thoughts on this item. Has anyone got one installed and did it make a difference? Is it worth thinking about? As I live in Australia the temperature here in brisbane Queensland doesn't really drop below 10oC. Not too sure what that is in Farenheit. That is even in winter. The average temp would be about 26oC and getting upto about 35oC. With this in mind is it worth me getting one or am I wasting my money?
As for the Unichip Q Version, when you custom tune it can you change the Idle rate and the O2 sensors for the High flow cat to stop the Check Engine Light coming on? My car Idles very lumpy due to my Head being ported and Polished and the cam and the Flywheel and everything else that has been done to it. I have been told that the increased Air Flow which messes with the Vacuum causing it to idle rough. This is why I would like to raise the Idle upto about 1000RPM. Any bodies thoughts on this would be much appreciated
Old Apr 17, 2007 | 06:08 PM
TLMCS05's Avatar
TLMCS05
UselessChip should come with it's own code reader cause your going to be throwiing a bunch more of them . Save yourself a lot of money and headache and send your ECU to LDG with a list of all your mods and all of your needs and let them do it right. Uselesschip cannot make the adjustments you want long term, ECU will keep learning and override it in due time. Been there, done that, 1k mistake.
Tim
Old Apr 18, 2007 | 08:20 AM
ECHO-313's Avatar
ECHO-313
Agree 100%. I made the same mistake, only cost me $750.00 and 18 months for a refund
Go to LDG. I haven't had a tune from them yet, but will at the dragon.
I've only herd good things about LDG.
UselessChip
Old Apr 18, 2007 | 09:34 AM
Guest's Avatar
Guest
Originally Posted by scolburn79
Hey,
Your looping idle is probably from your cam. Schrick's tend to do that. I don't know anything about the Unichip, but as others have suggested, with a heavily modified car, you'll see better results from a dyno or custom tune
Old Apr 18, 2007 | 11:18 AM
Beecher's Avatar
Beecher
lumping is defintly from the cam. uhmmm lopy idles, druelllll, hotrod season almost upon us, my race cam open headered car, uhmmmm, if only it would start at present....lol (not the mini, i only wish it sounded like that)
Beecher
Old Apr 18, 2007 | 01:54 PM
herbie hind's Avatar
herbie hind
you will really love the madness cooler. get the whole kit . it'll run about $525.00 . well worth it . and where you are ,you won't need a thermostat.
Colt45Magnus
Jul 14, 2019 06:18 PM
minicoclub
Nov 11, 2015 07:25 AM
minicoclub
Aug 25, 2015 09:07 AM
ludedude
Aug 10, 2015 07:16 PM
M7Speed
Aug 6, 2015 01:48 PM
