Drivetrain Magnaflow discussion
HI, I got the MAGNAFLOW and I dynoed completely stock on my friends Dynodynamics and then put on the MAGNAFLOW and redynoed it made only 4hp
but now that I have the pulley and ecu from randy its making alot more... I'll dyno again when I get the alta cold air intake
WS
WS
Here's my opinion:
When looking at airflow or aerodynamics, right angles lead to more disruptive flow. For a simple analogy, where would you have faster cornering speeds, at a 90 degree corner or a 45 degree offramp on the freeway? I would think that the Magnaflow with all the right angles would be more restrictive than the Borla. Maybe the difference from Magnaflow and Borla on an unmodded engine is that the Magnaflow gives a little more backpressure which increases hp. Then, when the engine is modded to breathe better, the Borla with a smoother airflow design results in higher hp gains. I don't know if this holds any water but I'm leaning towards the Borla as it seems more logical in its design.
("Y" pipe going into the mufflers and separate pipes out of the mufflers) :smile:
>>Randy any thoughts on this? The more mods you have the more advantageous it is for less backpressure/free-flowing exhaust?
>>Anybody with valuable knowledge please chime in
Give it up everyone, nobody really knows
Since nobody knows the answer to this I would suggest that you pick the one you think would provide more High RPM flow. Looking at them that would be the Borla. But you also have to consider sound. The two sound different, the tips look different and one has many more pieces. I personnaly like the Sound, simplicity and cost of the Magnaflow so that is the one I'm going to buy. If I find out later that the flow needs to be improved I'll remove it, weld in a smooth 'Y' pipe and separate the tips... It would probably sitll be cheeper than the Borla system and any exhaust service center could probably do it. My 2 cents...
BendersMINI
Sep 27, 2015 07:02 PM
daviday
Sep 25, 2015 01:31 AM
R53UndaPSI
Sep 21, 2015 09:42 AM
