Drivetrain UPGRADE THE GEARBOX
Old Mar 27, 2007 | 09:35 PM
harhoosh's Avatar
harhoosh
UPGRADE THE GEARBOX
Hi guyz.
Anybody knows about this ? yesterday i was talking with my friend ,, he said that between time to time. (Every Serivce) .. he toke his car to the dealer for upgrading his gearbox .. ?? IS IT TRUTH
Old Mar 28, 2007 | 03:52 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
If he had an 02-04 he might have went in for an 05-06 transmission instead. Starting with the 05 builds they revised the gear ratios to make it a wee bit quicker. The actual numbers of the gear ratios are available at MINI2 in the FAQ section.
Old Mar 28, 2007 | 09:47 PM
harhoosh's Avatar
harhoosh
Ahaa so i think i'll do it because my car is 03
so its possible ? how much they are gonna charge me for this ?
THANX
Old Mar 29, 2007 | 05:40 AM
gmcdonnell's Avatar
gmcdonnell
A new transmission is around $3500 plus install.
Perhaps your friend was talking about having the transmission oil changed each time he took the car to the dealer - that's much less, don't know exactly but probably less than $150.
Old Mar 29, 2007 | 05:47 AM
Loony2N's Avatar
Loony2N
If it's a manual, it doesn't actually have "oil" and changing it (manual or automatic) between every service is a waste of money unless you race all the time.
Old Mar 31, 2007 | 11:20 PM
harhoosh's Avatar
harhoosh
He told me that its a software ..
they upgraded with a software ?
Old Apr 2, 2007 | 06:37 AM
mmatarella's Avatar
mmatarella
I don't see how a software update would effect a manual, auto maybe. Could be a update that effects the throttle control around shifts, but I doubt it.
Manuals DO have oil, the MINI's is 1.8 to 2.1 quarts depending on model. It's used to lubricate the gears. Not for a torque convertor which a stick doesn't have and uses a different fluid. Don't know the spec for the MINI but most gearbox oils are around 90 wieght, the owners manual doens't say. It's not something that's changed or checked very often.
There was also a issue with some LSD"s 'groaning', and there was a change made for those that complained to a different fluid.
Old Apr 2, 2007 | 09:27 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
The '05 and later gearbox will just bolt up to the earlier cars. Look for cost in the $3000+ range for the box, then another 14-16 hours in labor for the change. We have done a few here.
The gearbox uses MTL fluid - which is a typical gear oil.
Your friend most likely has an auto, and the map can be updated through the ECU flash.
Hope that helps!
Randy
Old Apr 2, 2007 | 09:42 AM
MCS03's Avatar
MCS03
Transmission Swap
If you swap out a 03 6 speed and put in a 06 LSD 6 speed into the 03 do you have to do anything special to update the car's ECU? I had read some where that there may be issue's with the cruise control not working. Thanks....
Old Apr 2, 2007 | 09:53 PM
harhoosh's Avatar
harhoosh
HE own Manual Gear :s
cuz he told me.. after the upgrade.. he said that there was a big difference :S i dunno wut they did exactly
patsum
26
May 29, 2021 06:29 PM
Anakist
Sep 23, 2015 08:05 PM
Sep 3, 2015 02:06 PM
Sep 3, 2015 10:29 AM
