Drivetrain pistons?
Old Mar 9, 2007 | 02:10 PM
herbie hind's Avatar
herbie hind
pistons?
who was it that mentioned .020 over pistons for the mini? this is a just in case deal; ... knock on wood .
Old Mar 9, 2007 | 02:14 PM
Tüls's Avatar
Tüls
Turbius Maximus
Hubie and Brian from Fireballed would be a good place to start... I know they used them for people beofre
Old Mar 9, 2007 | 02:23 PM
herbie hind
well the tear down begins this summer . if need be (hope not ) i'll get it bored to .020 over . could add some torque !! but well above budget . that would mean porting and ccing the head myself with iffy results as i have no flow bench . so balancing the ports wouldn't be an issue but flowing them would . it'll be nice to get it healthy again .
Old Mar 9, 2007 | 02:26 PM
Tüls's Avatar
Tüls
Turbius Maximus
oh right on... well I will say that it takes agood amount of damage to need to go to .020 over... ussually just honing them out is enough... again... this is all good stuff for you to go over with the guys if you are unsure... :D
Old Mar 9, 2007 | 03:21 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
We have both stock bore and .020 forged custom pistons in stock if you need them.
Thanks Tuls!
Old Mar 9, 2007 | 03:32 PM
SharoSC02's Avatar
SharoSC02
What is the stock piston size (figure)?
Old Mar 9, 2007 | 05:05 PM
herbie hind
Thanks Tuls!
cool . whos pistons are you selling ? are they made for you ? if so ; good on you ,that's a heavy order . are they better at the top land then the stockers? and i assume they're well balanced . no .010 overs?
Old Mar 9, 2007 | 05:59 PM
MarioKart's Avatar
MarioKart
Vendor
I'm the one that has 20 over stock. I just got them from Fireballed the other day and were sent to the machine shop. The only reason I had to do this because the OEM piston had a hole through it and messed up the block. My motor will all so be balanced before going back into my Mini along with APR studs.
Mario
Old Mar 9, 2007 | 06:39 PM
AZMCS's Avatar
AZMCS
I am installing the Fireballed stock sized pistons in a couple of weeks. Should be able to give you all some feedback as to ease of install etc. I am not planning on pulling the crank. Just taking the head off, dropping the oil pan and exchanging the rod bolts for ARP's. Should be fun. I think JE makes the pistons, but Brian could confirm or deny this.
Old Mar 9, 2007 | 07:43 PM
astrochex's Avatar
astrochex
ENDYN also offers custom pistons in stock and overbore sizes.
http://www.theoldone.com/components/pistons/index.html
Old Mar 9, 2007 | 09:11 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
Our pistons are our own design, the ring lands are beefed up and there are some other design changes that went into them. We have made well over 400whp on these pistons on boost alone and even more with a little n2o, they have also seen 40 psi of boost so they are definitely strong!!!
We haven't done any .010 but we could if there is a need.
Right now we have a couple sets of stock bore and a couple sets of .020, no waiting, they are in stock.
Old Mar 10, 2007 | 04:44 AM
dmh's Avatar
dmh
Changing pistons is a fine idea for an engine that is controlled by a standalone ecu. But if you are using the stock ecu you are best to use the stock Mahle pistons. The reason is that the knock sensor is tuned for the frequency given off by the Mahle pistons. Due to different materials and designs aftermarket pistons, e.g., Wiseco, JE, CP, will give off a different frequency thus potentially hampering the entire system.
This notion was first introduced to me by John at Lucky Dog Garage. I confirmed this with a call to my contact (of 20 years) at Mahle.
Old Mar 10, 2007 | 06:11 AM
Beecher's Avatar
Beecher
Since the topic came up, does any of the aftermarket systems like mth or or the custom tunes still use the knock sensor and variable timing, or do the aftermarket systems eliminate that? Thanks
Beecher
Old Mar 10, 2007 | 08:44 AM
herbie hind
guess we need to learn how to read plugs again . does mahle make a bigger size? reason i ask is i think i've probly got a semy seized ring ; with possible bore damage ; though it's not burning oil . or if it is ,it's minimal . but the blow bye is certain. and the wet test was conclusive to rings . only one cyl. # 4 . not to stray too far ; but is the stock fly wheel neutral balanced? i was gonna get the crank checked ; but don't know what it's balanced at . i know guys are buying aftermarket flywheels but that's all i know on it .
Old Mar 10, 2007 | 08:57 AM
herbie hind
Beecher
i would assume they wouldn't eliminate a good insurance policy already in place . it wouldn't be good for business to be paying for engines . just my .02 . p.s. i think they can play with the timing a bit but i think the knock sensor is still functional . cool ?
Old Mar 10, 2007 | 10:00 AM
Tüls's Avatar
Tüls
Turbius Maximus
I have been running aftermarket pistons for almost two years...
while I agree with Don in some cases (like some of the EVOs I have see/done...VERY noisy...sound like TDIs..LOL) Hubie and the Brain....did alot of testing to ensure there was no ill effects... especially for the .020 pistons and have no problems with the car running as quite as stock and not pulling any timing due to it thinking there is knock from loose rattling pistons..
Old Mar 10, 2007 | 10:19 AM
herbie hind
i think what don is saying(not to put words in his mouth but ) is there is thought to be a danger of NOT pulling timing when an otherwise stock piston would . ; therebye allowing detonation to occur without the system knowing due to it being at the wrong freq. .
Old Mar 10, 2007 | 12:37 PM
isellem's Avatar
isellem
you are correct
Old Mar 10, 2007 | 12:45 PM
isellem's Avatar
isellem
aren't they just the CP pistons?
Old Mar 10, 2007 | 01:53 PM
Paul Webster's Avatar
Paul Webster
Don could you ask your contact what the safe horsepower limit of the Mahle piston is before they start cracking.
You say "thus potentially" have you or John tested any back to back under load and read what the timing is doing, if so how many degrees difference was there
Old Mar 10, 2007 | 04:23 PM
herbie hind
this is getting interesting yeah ?
Old Mar 10, 2007 | 04:26 PM
herbie hind
i always assumed knock sensors were getting pinging from the block . we would hit the block with a hammer to see if the timing would retard to see then if the sensor would be working . but the idea of a specific frequency keying on the pistons i.e. the weak link is cool .
Old Mar 10, 2007 | 08:02 PM
Tüls's Avatar
Tüls
Turbius Maximus
LOL again... it's a NONE issue.... I know the NAM is overly technical all the time... but ok ok ... so you read some blah blah blah in some book... that's great... anyway, call the guys at fireballed.... thier stuff is tried, true, tested, and just down right (as they say over the pond) proper....
again.. been running them for two years maybe more.... I forget....
Old Mar 11, 2007 | 06:49 AM
herbie hind
sounds good man . can you put this to bed and give the block a couple 'o raps to see if the knock sensor's workin' .
Old Mar 11, 2007 | 11:24 AM
Tüls's Avatar
Tüls
Turbius Maximus
kinda sure... but if this helps
for me...testing this stuff was.. or anything for that matter.... is not putting it on and starting the car... " OH IT WORKS!"
I took a week alone of dyno testing just watching timing, checking pinging... etc... the car took alot of abuse but the only way to truley know if somethign is right is to test it... and the cars ran the same... normal timing for 91 is around 18 degrees.... sometimes 20 if you get a good batch.... then on 104 gt plus it will just stick at 30 and hold.... it's beautiful.... and with the pistons... it was exactly the same... car was happy as stock... except there was one time where a car had some bad gas... lol... I have seen it pull till 6 degrees... very impressive that the mini has that kinda resolution....
