Drivetrain Magnaflow muffler dimensions
Old Apr 29, 2003 | 07:42 PM
LifeIsGood's Avatar
LifeIsGood
Could someone with a Magnaflow tell me the dimensions of the Magnaflow muffler?
Thanks.
Old Apr 29, 2003 | 08:03 PM
Yfoiler's Avatar
Yfoiler
Wow, there's a ton of deminsions.
Can you be more specific as to what you are looking for?
Suffice to say it's a perfect replacement fit for the stock exhaust, and one of the best as far as not having to "make it fit". I watched the install. It went flawlessly.
The finish is excellent too.
Only one gripe---and I've e-mailed the factory on it.
The seams for the tips are on the bottom and *UGLY* visible.
They should be on the top.
That way they wouldn't show and the tips would look seamless when viewed from the rear of the car. (scroll down and see pic.)
They also "jig" the resonator wrong for the MCS.
Their beautiful logo is on each side of the resonator and is not visible due to the MCS heat shield. If they rotate it 90 degrees when they weld it to the straight pipe in the jig, at least you could see the logo on the bottom. Then again, not many will be under there to see it--but I will and it would be a nice touch.
Here's the tips:
And here's the MagnaFlow installed. See how nice the inside of the *top* of the tips is? If they welded them on 180 degrees opposite that's what you would see when viewing the car from the rear.
Hope this helps some....
Yfoiler
Old Apr 29, 2003 | 08:09 PM
LifeIsGood's Avatar
LifeIsGood
I'm looking for the dimensions of the muffler. Not the any of the pipes. Just the oval shaped muffler.
Thanks.
Old Apr 29, 2003 | 08:10 PM
LifeIsGood's Avatar
LifeIsGood
By the way, thanks for posting the picture. That is a good shot of it.
Old Apr 29, 2003 | 08:12 PM
LifeIsGood's Avatar
LifeIsGood
From the picture, it looks as though the length of the muffler is the same depth as the battery box.
Old Apr 30, 2003 | 06:21 AM
LifeIsGood's Avatar
LifeIsGood
Anyone. Anyone. Class. Anyone.
Old Apr 30, 2003 | 06:24 AM
dave's Avatar
dave
pug poo picker-upper
Curious. What are you planning on using the dimensions for? I gather you have something else in mind.
patsum
26
May 29, 2021 06:29 PM
Costa_D
Oct 24, 2015 08:30 PM
BossyR56
Sep 28, 2015 11:33 AM
patsum
Sep 14, 2015 07:15 PM
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 7, 2015 07:51 PM
