Drivetrain My Own Engine Dampener Brackets
Old Oct 15, 2007 | 10:10 AM
  #51
LordOfTheFlies's Avatar
LordOfTheFlies
Originally Posted by HHFD633
Lord,
Are these a new style brack for your damper? I have one of your dampers with a different mounting style and it bent in a week from what seemed to be the angle.
What mounting style are you referring to?
What part "bent"?
Do you have any pics?
Old Oct 15, 2007 | 10:53 AM
  #52
HHFD633's Avatar
HHFD633
well the picture you are posting here is not the way my is mounted. My is mounted from inside the frame to the engine block. The picture posted here seems a lot easier to do and is at less of a angle (left to right) The actual damper shaft bent its seems do to the mounting angle. I have seen several others do this as well.
I wanted to get another and use the type of mounting pictured here it seems this will be easier to install and mounted in more of a stright line.
Old Oct 15, 2007 | 11:17 AM
  #53
LordOfTheFlies
Will send you a pm.
Old Oct 15, 2007 | 01:25 PM
  #54
Arly's Avatar
Arly
deflake,
I have a big washer below and above the mounting plate. My setup reinforces the existing damper, so the forces are distributed between the 2.
sleek55044
Aug 21, 2015 10:52 PM
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
Lt. Dan
Aug 10, 2015 08:23 AM
