Drivetrain HELP! unichip Flat spot!
Old Jan 16, 2007 | 06:34 PM
schooner2's Avatar
schooner2
So i bought a new unichip. And i installed it tonight on my 2004 JCW. I went out for a test ride and noticed a considerable flat spot in power at 5000 rpm. Does anyone know if it is required that i remove my JCW ecu program and return to stock programming? Last question! by having the unichip dyno tuned should that remove that flat spot?? I HOPE! any input of info would be greatfully appreciated.
Old Jan 17, 2007 | 05:31 AM
stevecars60's Avatar
stevecars60
5K+ is an odd place for a flat spot. What was the tune that was supplied with the chip? And have you tried both settings?
Old Jan 17, 2007 | 05:39 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
what map is on it? there is also a JCW map. it all depends on your mods. need more info.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Jan 17, 2007 | 07:20 AM
schooner2's Avatar
schooner2
Okay i had the unichip set to the only factory jcw configuration there was. which is jcw, alta cai, miltek cat/b, 15% udp, all header. that was the only jcw configuration they had, now my car has 2004 jcw with jcw injectors, alta cai, alta IC, shrick cam, 2% crank. The chip only has one switch which is I or O, and the paper work said the " I " was the high setting and the " 0 " was the low setting. I thought the " 0 " ment it was turning the chip off. So while running the car on " I " that is when i had the flat spot, and when i put the chip to " 0 " then it seem to be fine, but now the car is throwing a chech engine light and my DSC light is staying on! So i have removed the chip until i find out more info. Any Idea? I know they programming is not idea for the car but i thought it would be close enough for now until i get it dyno tunned. !!
Old Jan 17, 2007 | 07:30 AM
stevecars60
There should be a map number assigned with the chip that is the tune.
Old Jan 17, 2007 | 07:42 AM
schooner2's Avatar
schooner2
Yeah the tune number set by unchip is map 18010209.
Old Jan 18, 2007 | 07:20 AM
schooner2's Avatar
schooner2
No one has any suggestions?? I thought for sure someone would know the answer!
Old Jan 18, 2007 | 11:27 AM
stevecars60
You have the right map & it should work. Someone with more experience with Unichip will need to address your issue. Maybe a call to DT would solve the problem, they are a Unichip dealer ( agokart ).
Old Jan 18, 2007 | 11:41 AM
newbs49's Avatar
newbs49
Schooner2
Do you have a bigger TB on your car.
Old Jan 18, 2007 | 06:21 PM
Detroit Tuned
Vendor - 15 Years
Yes, give me a call as i think you have the wrong map on there, but i have a bunch of questions. if you can, call me early, as i need to leave for Ohio tomorrow afternoon. i think i have the info you need, i just have a few questions for you.
Chad
Detroit Tuned
Old Jan 18, 2007 | 06:32 PM
schooner2's Avatar
schooner2
Chad
Detroit Tuned
Thank you I will.
Here is a list of what the car has.
1- 2004 JCw
2- JCW injectors
3-JCW ECU Upgrade flash to go with injectors
4-Alta CAI
5-Alta Intercooler
6- Schrick Cam
7- Alta 2% crank pully
8- Nology Wires
9- Pilo coil pack
Old Jan 18, 2007 | 08:39 PM
pberry51mini's Avatar
pberry51mini
No Fear Gear
You're bouncing against the advance in the timing for the higher octane setting.
Flip the switch and you'll be happier unless you want to pay for some high octane racing stuff.
Paul
vetsvette
Oct 11, 2015 06:05 PM
Ovrclck
Oct 5, 2015 09:45 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
MINI Stupor
Oct 1, 2015 11:36 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
