Drivetrain Actual Customer ECU Dyno Plots
Old Apr 25, 2003 | 10:55 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
I hope Randy doesn't mind me reposting this from another thread, but this shows the difference the Superchips mod makes:
It's a little tougher to see since mine is split between two charts, but here is the difference the MTH chip made with the stock pulley and the 15% pulley:
Has anyone else dyno'ed the difference just a chip makes (I am deliberately omitting those dynos performed at the facility who developed the chip, on the spot)?
Old Apr 25, 2003 | 11:24 AM
Trippy's Avatar
Trippy
It's not perfect, but maybe this will help.
Old Apr 25, 2003 | 12:03 PM
andy@ross-tech.com
Hehe, nice animation! The dyno boogie!
Disco Stu has a dyno for you:
Old Apr 25, 2003 | 02:28 PM
MCSHP's Avatar
MCSHP
Andy,
I though we agreed that you cannot compare a dynoJet dynosheet to a Mustang dyno sheet. Apples and Oranges. Simply not a fair compairson.
Old Apr 25, 2003 | 08:11 PM
andy@ross-tech.com
Who is comparing a dynojet to a mustang? You should take the time to read and comprehend before posting.
Old Apr 25, 2003 | 08:24 PM
macncheese's Avatar
macncheese
I think its because one is metric.
Old Apr 26, 2003 | 12:10 AM
Rocketspeed's Avatar
Rocketspeed
Assuming I understand them correctly, the graphs show that the chip adds 12 to 15 lbs.ft of torque of most of the range. Since the "base" (without the chip) and the "test" (with the chip) were done the same day on the same dyno, the results should be valid. I believe this level of improvement is significant, especially if you race or autox.
_________________
'03 MCS EB/RDY
Old Apr 26, 2003 | 04:52 AM
andy@ross-tech.com
I think you are looking at the wrong graphs.
Old Apr 26, 2003 | 05:29 AM
greatgro's Avatar
greatgro
No, no, no. Thew chip made an increase of FOUR torque and HP over the stock chip.
Old Apr 26, 2003 | 08:54 AM
Rocketspeed
Ok. It seems that my assumption that I was understanding the graphs was wrong. So, for both Mustang Dyno graphs, the "base" is without the pulley and the "test" is with the pulley. The graphs marked 11:36am are without the chip and those marked 11:23am are with the chip. If this is true, then the maximum gains, at the wheels, are 4.5 lbs.ft of torque and 4.6hp.
Also, Trippy's oscillating graph is switching between the with chip and without chip graphs. Nice work Trippy.
_________________
'03 MCS EB/RDY
Old Apr 26, 2003 | 10:05 AM
greatgro's Avatar
greatgro
You got it Rocketspeed!
USA-RET
Nov 9, 2015 07:27 PM
molala
Oct 2, 2015 01:53 PM
ShadyCoop
Sep 11, 2015 11:14 AM
