Drivetrain Calling all chemists/ physicists
Old Dec 15, 2006 | 03:33 PM
NMgokart's Avatar
NMgokart
And even economists.
This may be better suited for a different forum, but I know you guys are in to this stuff:
How is the AFR affected by ambient temp variations? I know colder air makes more power, but what is the effect of colder temps on MPG? (assuming that you can keep your right foot from enjoying the increase in HP).
Old Dec 15, 2006 | 03:36 PM
ChrisW's Avatar
ChrisW
Cold weather can reduce fuel economy, since your engine doesn't operate efficiently until it is warmed up. In colder weather, it takes longer for your engine to warm up.
Old Dec 15, 2006 | 03:38 PM
Eric_Rowland's Avatar
Eric_Rowland
Cold air just means more oxygen. More oxygen means more fuel.
All else equal, you shouldn't get better or worse mileage due to air temp. Then again, if you let the engine warm up longer in the cold, or use the AC when it's warm...
Old Dec 15, 2006 | 03:39 PM
NMgokart's Avatar
NMgokart
Let's assume, for the sake of argument, that warm up is not an issue.
Equal cars, at op temp, driving in 25F vs 50F, all other factors equal. Which gets better fuel economy?
Old Dec 15, 2006 | 03:43 PM
chows4us's Avatar
chows4us
The one with the elephant in the trunk gets worse
Old Dec 15, 2006 | 03:49 PM
AliceCooperWA's Avatar
AliceCooperWA
I don't think it increases fuel consumption. The only way to tell would be whether the air temp sensor effects the amount of fuel entering the engine. I think the cold air just lowers the temp of the fuel mixture. This should require more energy to ignite it, while also producing more energy from the explosion. It seems to me that this shouldn't effect the mixture, it would just make for a more powerful explosion of the mixture.
Old Dec 15, 2006 | 03:54 PM
NMgokart's Avatar
NMgokart
EQUAL cars, furry one.
Old Dec 15, 2006 | 04:05 PM
T2Nav's Avatar
T2Nav
Also consider the density of the cold air you're plowing your car through. Colder air means that at a given speed you are bumping more air molecules out of the way as you move along. If you fly, think higher indicated airspeed to fly the same true airspeed on a colder day. I vote for very slightly reduced mileage on a cold day.
Old Dec 15, 2006 | 04:06 PM
Motor On's Avatar
Motor On
Equal cars get equal MPG
Factor in speed as well, deser air means more drag. What about altitude? Wieght? Mods? Barometric Pressure? Humidity? Summer or Winter wheels/tires? are you running defrost? Widnows down in heat and up in cold?
FYI my Physics prof hated me as I often looked at all factors and even got him to say "ignoring the laws of science" just to get me to look at the question. Temp alone with out ECU should have little to no effect on milage, in theory; but I think this is cause for some lab testing with Bim-COm (Yes I still want it!!!).
Old Dec 15, 2006 | 04:12 PM
chows4us's Avatar
chows4us
That is true. However, it also depends, then, upon the color of the car as its well known that different colors go faster (dont laugh).
For example, to get some odd ball colors like some metallics, the paint has to be heavier to account for the metallics in the paint and possibly more layers.
Thats why CR/W is always the fastest.
Old Dec 15, 2006 | 04:32 PM
TonyB's Avatar
TonyB
At least as it stands now in the US, in colder air/climates, one gets more fuel for their money...
Old Dec 15, 2006 | 05:20 PM
AliceCooperWA
If the air/fuel mixture is effected by the air temp sensor, then it will put more fuel in with the air to keep the mixture from being too lean. If you take advantage of the extra power...you will use more fuel. This in addition to the denser air you are driving through...definitely more fuel consumption. It might only 1 mpg though. It's worth the added power though.
Old Dec 15, 2006 | 05:31 PM
kapps's Avatar
kapps
Colder temps DO reduce gas mileage. We also own a Honda Insight and this topic is very big over on their forums. Colder air means denser air, which means more fuel molecules are needed to keep a stoichiometric A/F ratio. It's just like running a reduction pulley...more air needs more fuel to keep stoich.
If you run the same car in 25 degree air and 80 degree air, the one in 80 degree air will get better mileage. This, of course, means you can't run the A/C when it's 80. The A/C eats more mileage than the colder air.
Old Dec 15, 2006 | 05:45 PM
isellem's Avatar
isellem
not that it really really matters for the point of this thread. But MINIs do not run at a stoichimetic A/F. Most cars with cats don't... it would burn them out in a hurry. Insights and piruses may be equiped with special cats that can run at the higher EGTs. or they may not and they may not run at stocihiometric a/fs.
also, the difference between cold weather mileage and warm weather is negligable. Too many other factors involved to get an exact answer. the best thing to do would be to have a climate controled engine dyno... that would be the only true way to find out if the engine used more fuel. whether or not cold weather has a huged effect on drag on a car going 50mph is a completely differnt story.
Old Dec 15, 2006 | 07:38 PM
kapps's Avatar
kapps
I know but the computer is still trying to keep a set A/F ratio, even if it isn't stoich. The gas mileage difference might be negligible in an MINI but it's very noticeable in an Insight. As the temp drops near freezing, gas mileage really takes a hit.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
elverado
Jan 18, 2022 02:51 AM
Sep 10, 2015 10:52 AM
Panik
Sep 9, 2015 08:36 AM
