Drivetrain What is the better ignition solution?
Old Nov 29, 2006 | 06:05 PM
00zero's Avatar
00zero
which is better...
nology hot wires or a blaster coil with kingsborne wires
the price is about the same so which is it?
this is given the same plugs ect.
-jonathan
Old Nov 29, 2006 | 06:12 PM
ScottRiqui's Avatar
ScottRiqui
Originally Posted by 00zero
which is better...
-jonathan
The Nology Hotwires (and all the similar designs over the years) have proven pretty ineffectual, but I guess they're pretty.
Seriously, unless you have some evidence that you're not getting complete combustion, there's nothing to be gained by changing out the coil or wires. Are you running higher rpms than normal (for instance, you've lightened your valvetrain and are now regularly revving to 8000 rpm)? Or have you drastically increased your dynamic cylinder pressure and are having problems getting the air/fuel mixture to ignite?
In short, what's the problem you're hoping to fix by changing out the ignition components?
Scott
Old Nov 29, 2006 | 06:26 PM
obehave's Avatar
obehave
Scotts points are dead on.
To answer the question though. I wouldn't do anything unless I went with something like the MSD DIS systems.
Old Nov 29, 2006 | 06:57 PM
IrishCooper's Avatar
IrishCooper
i went with Kingsborne wires just cause i wanted red wires, it was purely cosmetic.
Old Nov 30, 2006 | 03:53 AM
TampaMCS's Avatar
TampaMCS
Yep, unless you are running a twurbo or some crazy amounts of boost, the stock stuff works just as well.
Old Nov 30, 2006 | 04:46 AM
NMgokart's Avatar
NMgokart
Well, stuff does wear out, eventually.
On a newer car, I agree with the above. On an older car, might be worth it.
My 03 has 42k on it, and when I switch plugs for the pulley, I will probably switch wires and maybe the coil. More of a peace-of-mind thing.
Old Nov 30, 2006 | 11:31 AM
00zero's Avatar
00zero
it was more a hypothetical quesiton. i dont need either i was just curious.
-jonathan
rikaro
Nov 24, 2015 02:05 PM
vulkandino
Oct 31, 2015 08:29 PM
Suspension Products
Oct 1, 2015 11:53 AM
bradstyle
Oct 1, 2015 11:15 AM
