Drivetrain Replacing IC - Should I do anything else?
Old Nov 21, 2006 | 02:05 PM
XAlfa's Avatar
XAlfa
Just wondering what if anything I should plan on doing while replacing my IC. I'm at about 50k. The new one will cover the plugs, so I may just swap those out. Anything else I should replace or clean while I'm in there?
Thanks in advance for any advice.
Old Nov 21, 2006 | 02:10 PM
MSFITOY's Avatar
MSFITOY
Maybe install the Ram Intake? I take it you're installing either an Alta TMIC or GRS...
Old Nov 21, 2006 | 02:39 PM
fishbulb's Avatar
fishbulb
I just took mine off to do the VGS mod....it's not that hard to do if you need to take it off again.
Old Nov 21, 2006 | 02:40 PM
XAlfa's Avatar
XAlfa
It's actually a GP unit. I'm an OEM kind of guy...
What's the Ram Intake, a modified hood scoop?
Old Nov 21, 2006 | 02:55 PM
MSFITOY's Avatar
MSFITOY
Something we designed for M7...
http://www.m7tuning.com/main.m7/store/10035
https://www.northamericanmotoring.co...intake+project
Old Nov 21, 2006 | 03:12 PM
XAlfa's Avatar
XAlfa
Oh, I see. That is quite sweet. I have the JCW CF scoop, but would consider replacing it. Does your design hook up with the stock "diverter" on the underside of the hood, or have it's own? (I ask becasuse the GP unit comes with a matched IC cover and diverter.)
Old Nov 21, 2006 | 03:18 PM
MSFITOY's Avatar
MSFITOY
It would take a bit of explaining but if you have the time, please go through the link that I sent you...everything is explained in there
Old Nov 21, 2006 | 03:24 PM
RA080624's Avatar
RA080624
have you guys ever thought about the cowl scoops and moding those so they scoop air into them or would that be a waste?
Old Nov 21, 2006 | 03:26 PM
MSFITOY's Avatar
MSFITOY
There are already a few ongoing threads regarding these ideas...
Old Nov 21, 2006 | 04:10 PM
XAlfa's Avatar
XAlfa
Got it, thanks. Sounds like some minor tweaking of the stock diverter is all that would be required. But $200 for a raw FG piece seems very steep to me.
Old Nov 21, 2006 | 04:23 PM
MSFITOY's Avatar
MSFITOY
Inspite of the price...the performance benifits are more than worth it for me...
Old Nov 21, 2006 | 04:40 PM
XAlfa's Avatar
XAlfa
Of course it's worth it for you. You get yours for free...
Old Nov 21, 2006 | 04:49 PM
MSFITOY's Avatar
MSFITOY
I created the product...that didn't happen out of thin air If I charged my usual rate, I'd have enough Ram Intakes to make soup...old Chinese saying...
Old Nov 23, 2006 | 11:52 AM
blackie's Avatar
blackie
Here are some photos on point to this discussion of what I just installed today, thanks to Dr. Phil, who supplied both the parts and the know-how. I was in the right place at the right time when the good doctor decided to dispose of his former M7 CF Ram Intake and the related Alta diverter (that he also further customized). Also, notice that the M7 strut brace and M7 CF air diverter are also installed as well. Unfortunately, I found the hard way that the M7 CF air diverter will develop scars from the bonnet's front screw placements along the lip, so I have applied two small clear rubber bumpers (the type sold in framing shops to be used on the back side of picture frames) to avoid further damage. My advice to anyone purchasing this nice addition be alert and determine a means of addressing prevention of this condition; there may be better ways than what I have tried and I would love to see a discussion of successful solutions.
Old Nov 23, 2006 | 07:06 PM
trickedmotoring's Avatar
trickedmotoring
so... where did you pic up the gp intercooler....
Old Nov 23, 2006 | 07:11 PM
blackie's Avatar
blackie
It is the standard MCS intercooler, not a GP. Why, did it look like one with the Alta diverter on it?
Old Nov 23, 2006 | 07:49 PM
cooldaddy's Avatar
cooldaddy
I think he's asking XAlfa that question
Old Nov 23, 2006 | 08:51 PM
blackie's Avatar
blackie
OK; I see that now and I guess it helps to go back through all of the thread when something doesn't quite make sense.
Old Nov 23, 2006 | 09:52 PM
cooldaddy's Avatar
cooldaddy
got a question about your car; are the small braces just above the 'eyes' only on the convertibles? I've never seen those before (short braces just below the strut towers).
Old Nov 23, 2006 | 10:46 PM
blackie's Avatar
blackie
Not sure; I have not looked under too many hoods to notice the difference. I am sure someone here though knows.
Old Nov 24, 2006 | 05:00 AM
fishbulb's Avatar
fishbulb
the cabrios have some extra bracing - those by the eyes are two of the extra braces.
Pretty sure there is more bracing that you can not see in the rocker panels and the A pillars.
Old Nov 24, 2006 | 05:30 PM
XAlfa's Avatar
XAlfa
My attorney has advised me not to answer this question.
Old Nov 25, 2006 | 05:19 AM
blackie's Avatar
blackie
<snip> Unfortunately, I found the hard way that the M7 CF air diverter will develop scars from the bonnet's front screw placements along the lip, so I have applied two small clear rubber bumpers (the type sold in framing shops to be used on the back side of picture frames) to avoid further damage. My advice to anyone purchasing this nice addition be alert and determine a means of addressing prevention of this condition; there may be better ways than what I have tried and I would love to see a discussion of successful solutions. <snip>
Well, my bad; I misspoke about the cause of the scars on my M7 CF Air Diverter. I have now determined that the scars came from the screws that hold the brackets for my driving lamps, so if you have the driving lamps braced to your grille (like the ones sold by Mini) and you get the M7 CF Air Diverter, be alert to the location of these 4 screws (2 on each driving lamp bracket) when the hood is closed and they come in contact with the diverter. Rather than placing rubber bumpers directly on the diverter, a better answer may be placing adhesive-backed rubber cushioning to the 4 screw heads. Again, anyone else noticing this issue should offer their own takes on possible fixes.
eliseo1981
Jan 28, 2021 02:45 PM
woodstudio
Mar 15, 2020 08:28 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
Knuckle14
Aug 26, 2015 08:10 PM
JPMontes3
Aug 23, 2015 01:26 AM
