Drivetrain Service engine soon Light?
Old May 7, 2007 | 02:33 PM
  #26
Scavenger's Avatar
Scavenger
two cars too rich
I had the SES light on both ways to and from MOTD. The other MINI I Motored with on the way back home also had it. I don't know the reason for theirs, but I know mine was saying system too rich. One of the vendors that pulled the code said its possibly due to getting some gas with too much Ethanol, as was mentioned earlier in this thread. Interestingly, once this light came on, my exhaust became unbearably loud! I could go into a longwinded bunch of speculation, but first, I'd like to just see some opinions on this. I am planning to have my dealer take a look at it since I'm under warranty.
Old Jun 13, 2007 | 09:58 PM
  #27
paulgrant's Avatar
paulgrant
I've gotten the "check engine soon"light after installing a Miltec exhaust. I have a 15% pully,Dneso IK22's,and Web CAI and RAF.
Old Aug 13, 2007 | 11:45 AM
  #28
MPETUOS's Avatar
MPETUOS
I need to revive this thread........ I have the exact symptoms as described by Scavenger. Has anyone else experienced this? And if so what did you do to correct the problem?
Thanks in advance!!
Old Aug 14, 2007 | 12:43 PM
  #29
pmfranke's Avatar
pmfranke
just bought my car(03 19% pullie ,milteck exaust,alta intake ,big intercooler)and the next day the service soon light came on.I'm new to this so i need help.Thanks in advance
Old Aug 16, 2007 | 08:31 AM
  #30
Peter W.'s Avatar
Peter W.
I find it that everytime I reach 17 psi or more in my car, the SES light comes on and the DSC light. The SES light will turn off after 3-4 starts of the engine. I guess it is an overboost code that triggers these lights to come on. Hope this helps.
Old Aug 20, 2007 | 09:26 PM
  #31
chisss's Avatar
chisss
I just installed the 15% pulley and OBX headers with the Stock cat and I get the P0171 System too lean... I rechecked the boots but it's still there.. any suggestions???
Old Sep 28, 2007 | 10:15 AM
  #32
WP4LDU's Avatar
WP4LDU
Overboost solution!!
Check your intercooler boots and make sure they are super tight. But if you are running 17% pullies and getting the SES lights you need to change to the Alta Couplers (BOOTS).
I have had the same problem with my 17%v2 Alta Pulley. I replaced the stock IC boots for the Alta IC Boots (Couplers) and no more problems. The stock boots were too soft for my 17% pulley at higher speeds. I was getting the P0108 code all the time after pushing my car hard, and after replacing the intercooler boots for the Alta. My problem is gone. Henry
Old Sep 28, 2007 | 10:34 AM
  #33
SharoSC02's Avatar
SharoSC02
I have had my SES light on from the 1st day after I had the 180 thermo installed.
Old Jan 8, 2015 | 07:30 PM
  #34
zamfield's Avatar
zamfield
Old thread, I know but I've searched the forum and I'm not seeing a fix.
I've got the same issue... Rev high 4k - 5k and the service Engine Soon Light comes on.
Is it really an IC boot issue?
09R56
Nov 16, 2022 10:49 AM
W0TM8
Dec 19, 2019 07:50 AM
oldkid6
Aug 11, 2015 08:13 PM
