Drivetrain Gauge install with DFIC
Old Oct 26, 2006 | 03:40 AM
Larry Clemens's Avatar
Larry Clemens
What is the best way to install a boost gauge? I have the M7 DFIC. Which gauge(s) best match the OE gauges?
Old Oct 26, 2006 | 06:43 AM
MiniMacPR's Avatar
MiniMacPR
There's a sticky thread on the electrical modifications forum for an Autometer Boost Gauge install:
https://www.northamericanmotoring.co...ad.php?t=58578
That should be a good starting point...
Old Oct 26, 2006 | 08:21 AM
eMINI's Avatar
eMINI
I believe Autometer Ultralite II guages are lit through the face like our OE gauges, and may look like OE both during the day and at night. Can anyone confirm this?
Old Oct 26, 2006 | 08:48 AM
HHFD633's Avatar
HHFD633
doesnt the m7 dfic have a welded in boung for a boost gauge.
Old Oct 26, 2006 | 09:04 AM
chaincoopers's Avatar
chaincoopers
Two - one pre- and post-core.
Old Oct 26, 2006 | 09:22 AM
pberry51mini's Avatar
pberry51mini
No Fear Gear
Those would be good places but the aforementioned thread:
https://www.northamericanmotoring.com...ad.php?t=58578
does have an easier route to take.
My Promini gauges came with great instructions for connecting the boost gauge input, coupling it in with my VGS mod back when I had the VGS mod.
I personally think the Promini set is better and more Mini oriented (looking) than the others.
Paul
Old Oct 26, 2006 | 10:05 AM
latte hiatus's Avatar
latte hiatus
Tapping into the vacuum line below the fuel regulator (as detailed in the aforementioned thread) takes a little more work, including removing the IC, and the hose can get a little hot when run from that location. It would also be a little more inconvenient to service if a hose pops loose.
On the other hand, using the post-core DFIC bung would be easier in terms of actual installation, but you'd have to find a 1/8" NPT male x 1/8" hose adapter. That shouldn't be terribly difficult, but I wasn't able to locate one locally after a half-hearted effort.
That said, I wanted to save the DFIC bung for possible water injection in the near future, so I followed the first method above. Make sure to use a hose clamp on the tee fitting for the connection running to the gauge - I didn't the first time, and the hose popped loose after 70 miles. :impatient
Old Oct 26, 2006 | 10:33 AM
M7's Avatar
M7
Hi Guys....
Here's a visual representation of how to tap in to the DFIC, this particular car
used the bungs for thermocouples. I got some 1/8" NPT plugs with a hose coupling from ACE hard ware. If you like to call us, we can sell you one
for a couple of bucks + ship.
peter
Team M7
562-608-8123
DFIC bungs....
Old Oct 26, 2006 | 12:03 PM
TonyB's Avatar
TonyB
Very clean instal Peter. Almost Sid-like...
I just realized that while the reported temp deltas (pre & post core) for the DFIC have been nice, given the bung location, they are even better than what we see. What I mean is that the best cooling is happening toward the front of the the DFIC, while the rear portion, where the bungs are located, receives warmer than ambient air. So, the actual IAT should be lower than what the post core thermocouple registers...
Old Oct 26, 2006 | 12:17 PM
obehave's Avatar
obehave
Your temps may be skewed but the temp differential across the IC will be much closer. That difference is more important than actual slight variations in temp.
There's quite a bit of swirl going on inside the end tanks so I can't see the difference being too far off.
Old Oct 26, 2006 | 12:23 PM
chuckt's Avatar
chuckt
You could probably rig one of these in there and get both Temp & Pressure.
Old Oct 26, 2006 | 12:31 PM
MSFITOY's Avatar
MSFITOY
Only a "couple of bucks" Now you tell me
Mine didn't fit the bung so I tapped into the bottom/center...this should provide an average between front to back temp variances...
DFIC is upside down in this image...
One gauge, two reading...
Bung used for digital boost gauge...in this case, pre-IC boost...I switch back and forth and sometimes use both to get an average reading...
Originally Posted by M7
Hi Guys....
peter
Team M7
562-608-8123
DFIC bungs....
Old Oct 26, 2006 | 12:35 PM
TonyB's Avatar
TonyB
That's what I thought initially, but after reading other forums, and their experimentation with thermocouple placement, there is a difference, and I would think even more so with a thicker core like this one.
It would be neat to see what the exit temp is out the back, but I would guess it's quite a bit warmer than when it entered (ambient). That being the case, the charged air getting funneled toward the rear of the DFIC is getting the worst cooling benefit (still very good, apparently), and with the thermocouple positioned at it's exit, it will more easily encounter the highest of the temp range exiting the core.
If the thermocouple is registering let's say 95 degrees F, it might be 89 in the front, with 92 being the actual IAT.
With traditional top-mounts (down-drafters) needing help to divert air to the forward portion of the core, a similarily placed thermocouple would be more inclined to read lower than actual IATs...
Old Oct 26, 2006 | 01:12 PM
obehave's Avatar
obehave
Definitely Tony.
I wasn't disagreeing with that part.
All I am saying is that the readings on both sides will be biased because of this and the temp drop across the core will be consistent.
So your resulting TE may be skewed slightly (depending very much on the amount of error) but the drop will be repeatable.
Once everything gets squeezed together in the remaining induction path it averages out anyway.
Shouldn't be too hard to find extensions for thermocouples. I saw them all the time when I did wind tunnel tech support.
Old Oct 26, 2006 | 02:42 PM
TonyB's Avatar
TonyB
Obe, I thought about a longer thermocouple also, but I'm sure that can't be beneficial to flow dynamics either; but would interesting to see for curiousity sake...
The temp variance in the pre end tank is probably very minimal, if any as it's simply beat-up SC air. The post end tank temps will see lower temps due to the effect of the core acting as a heat-exchanger of course. The temp variance within the post tank would seem to be not nearly as constant as seen on the pre core side; but gradually warmer toward the rear...
Just a realization that I had upon seeing that above photo with the thermocouple placement is not the most ideal position to read the most accurate output temp in the exit end tank. A thermocouple in the middle would most likely yield a truer measure of the actual overall temp, and with that, a more definitive delta and the core's efficiency.
Old Oct 26, 2006 | 03:54 PM
jymontoya's Avatar
jymontoya
Sweet! I want one for my DFIC! I was gonna do to the fuel pressure reg, but this is MUCH easier.
Peter! Drop me a line so I can order those fittings!
Old Oct 26, 2006 | 06:18 PM
obehave's Avatar
obehave
Don't know how much flow really matters in the rather turbulent environment of a supercharged system like ours.
Also the probes, like the ones Sid uses, are 1/8th to 3/16ths in dia. maybe 4" long should work.
Something like this:
http://www.coleparmer.com/catalog/pr...0844110&pfx=EW
Old Oct 26, 2006 | 09:46 PM
TonyB's Avatar
TonyB
Seems like it wouldn't hamper flow all that much... But then folks spend quite a bit of money to clean-up the rough surfaces within, feeling that it is worthy to not have obstructions.
For those who are not using their stock boots, and still have them, this would be a neat experiment. Instead of a pre/post core delta, put both in the post boot, one in the front, and the other in the rear. These probes would be further from the core though (as compared to the bung) so there would be more mixing of the air at that point, and the delta less evident...
I think the long thermocouple would be the way to go then. Is only the tip of that thermocouple "active," or is the whole length influenced by temp? If the entire 4" length, then it would probably provide the best accounting of the actual temp, and might want to be considered as a permanent solution. However, if only the tip registers temps, then it would be ideal to see the temp delta from front to back...
Still looking for a nice gauge that shows both temps simulataneously, and is responsive enough to show rapid changes up & down.
Old Oct 27, 2006 | 06:59 AM
Bahamabart's Avatar
Bahamabart
M7 - Any news on the dual temp guage?
MISFITOY - how much was that guage ? should I be sitting down?
Old Oct 27, 2006 | 07:59 AM
chuckt's Avatar
chuckt
I've seen it for around $280 , google "VR intercooler temp" gauge
Old Oct 27, 2006 | 10:38 AM
obehave's Avatar
obehave
I've seen them with just the tip being the active component but honestly have no idea how to spec them. I do know a couple people I could call if no one on here knows.
I do know that the faster the response time the more expensive they get.
Very interesting idea on the temp measurements front to back. I'd like to see that as well.
Old Oct 27, 2006 | 12:31 PM
TonyB's Avatar
TonyB
I attempted some probbing (ha!) on thermocouples here:
https://www.northamericanmotoring.co...t=thermocouple
Chossing the most appropriate type, and then a guage that reacts fast enough to make it worthwhile, just bogged-down my pursuit any further.
Old Oct 27, 2006 | 12:50 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
The Vivid Racing (VR) Intercooler Gauge is pretty cool and $279 all up. But the website does not indicate how big the probes are. Sid, would they fit the 1/4" NPT bungs on the DFIC?
cheers,
Old Oct 27, 2006 | 04:18 PM
chuckt's Avatar
chuckt
I think the bungs on the DFIC are 1/8" NPT... but then I don't have one to check.
Old Oct 27, 2006 | 04:31 PM
M7's Avatar
M7
1/8" NPT it is...
Peter
Team M7
562-608-8123
