Drivetrain Intercooler Theory
Old Oct 9, 2006 | 07:06 PM
  #51
checkers's Avatar
checkers
For the little time it takes for the dyno run it dosen't need it. It's not much diffrent than idling at a stop lite.
Old Oct 10, 2006 | 05:27 AM
  #52
obehave's Avatar
obehave
Yea OK
Old Oct 10, 2006 | 08:22 AM
  #53
Dr Obnxs's Avatar
Dr Obnxs
W2a
have quite a bit of heat capacity in them. Eventually, the water will heat up and then it will be an issue. But because the water can act like a heat sink, it can "store" coldness (yeah I know, not a real term) until when it's needed. The amount of dyno runs you can do before degradation is a function of how often you do a pull, how much water is in the cooling loop, and how much (if any) air flow is going over the w2A radiator. But for sure, the systems are more forgiving......
Matt
Old Oct 10, 2006 | 11:10 AM
  #54
checkers's Avatar
checkers
The last time I had it on the dyno I had a power difference was about 2HP over 3 runs in about 20 mins. It was like looking at a single line on the chart.
I had some friends run there's at the same time but with air cooled IC's and the difference was about 10 to 15 HP for the same runs.
Old Oct 10, 2006 | 02:16 PM
  #55
Bahamabart's Avatar
Bahamabart
well that certainly says something - doesn't it.
IQRaceworks
53
Jun 28, 2024 07:29 AM
gar56
Nov 15, 2016 06:41 AM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
