Drivetrain Oil Pressure Gauge Problem HELP!
Old Sep 20, 2006 | 04:59 PM
Peter W.'s Avatar
Peter W.
Ok my oil pressure gauge WAS working normally I think. When I would start the car it would read below 25 at idle then reach a max of about 50 more or less when driving. Last week after I had some seats installed with an ohm(?) resistor put in to turn off the airbag light, my pressure gauge is at 0 at idle then only rises to about 25 after an hour of driving. I don't think this is normal. The gauge barely moves. I checked the wire and it is good. Does anyone know what the problem here is. Any information would be great. Thanks
Old Sep 20, 2006 | 05:43 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Is it mechanical or electrical? It sounds electrical, and if that is the case, I would check the power source you are pulling from for the gauge. My guess is that you are putting a resistor in that line, causing your gauge to read, but low.
Hope that helps!
Randy
Old Sep 20, 2006 | 06:18 PM
herbie hind's Avatar
herbie hind
the airbag resister is in the same circuit as your gauge probably so there is less available voltage to drop across the gauge .(they are in series).
Old Sep 20, 2006 | 08:30 PM
Peter W.'s Avatar
Peter W.
Where can i put the new power source for the gauge. I don't want to mess with the resistor put in for the airbag light because i had that done for me, real complicated for me. Can I tap a new source for the power for the gauge and would any of you two guess where my power source is now? Thanks for responding. Peter
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
JamJam43087
Aug 16, 2015 02:02 PM
dchang0
Aug 10, 2015 03:37 PM
