Drivetrain DFIC/diverter
Old Aug 13, 2006 | 04:04 PM
hornguys's Avatar
hornguys
DFIC/diverter
Love my DFIC.
However, I wonder if I'm getting all there is to get from it.
My chrome diverter's hoziontal plate meets the front surface of the DFIC exactly one row of air inlets too high.
In other words, the bottom row of air inlets on the DFIC get no ram air whatsoever.
They are blocked off by the air diverter, which meets the front of the DFIC just above the bottom row.
Seems like the only fix is to raise the DFIC. Don't know how, though.
Dropping the diverter doesn't seem possible, as it's already mounted solidly at the two attachment points.
So two questions:
(1) What am I doing wrong?
or
(2) Is there a simple fix that I just don't see?
Old Aug 13, 2006 | 04:42 PM
obehave's Avatar
obehave
Sorry I can't help but can you do pictures?
That has to help the people that have done the install. Maybe they can spot something.
Good luck
Old Aug 13, 2006 | 06:55 PM
hornguys's Avatar
hornguys
Unfortunately, I have to leave on a business trip and can't until the end of the week.
Old Aug 13, 2006 | 07:52 PM
SpiderX's Avatar
SpiderX
Dave at DDM fashioned a bracket to fix that on CustomAV' s car and I am going to ask him to do the same for mine
Old Aug 13, 2006 | 08:31 PM
hornguys's Avatar
hornguys
OK, I'm not crazy.
When I get back, maybe I'll ask Harrison if they can do something.
Thanks!
Although I hafta say, it's pretty dang good now...
Old Aug 13, 2006 | 08:47 PM
Longboard Mini's Avatar
Longboard Mini
Originally Posted by hornguys
OK, I'm not crazy.
Thanks!
I don't have that problem?? Not to be a jerk but are you sure you don't heve it upside down??
LongBoard
Old Aug 13, 2006 | 09:28 PM
M7's Avatar
M7
LongBoard
Hi Guys......
Each and every car has small differences in the height of the IC. We had to
shave some material of the mounting posts with a dremmel to lower the diverter on one car, on another (maxminis) two small slits on each side
with a little bit of bending and you'll be there.
And as always....Call me if you need tech help...
peter
Team M7
562-608-8123
Old Aug 13, 2006 | 10:32 PM
pberry51mini's Avatar
pberry51mini
No Fear Gear
Originally Posted by M7
Hi Guys......
peter
Team M7
562-608-8123
Good to know as I expect I will be putting mine on soon.
Pablo
Old Aug 14, 2006 | 05:57 AM
hornguys's Avatar
hornguys
Hi Guys......
peter
Team M7
562-608-8123
Thanks Peter,
Getting ready to take a trip this week with auto-x the first day I'm back.
Didn't wanta bug you on a Sunday.
Even so, you stepped in. Thanks!
I had thought of the slit and bend approach.
Raising the DFIC is probably not a good idea anyway as it would likely stress the boots.
Old Aug 14, 2006 | 09:00 AM
SpiderX's Avatar
SpiderX
OK, I'm not crazy.
Thanks!
I am very glad you like it....your turning your car into a monster....a little different than what you said at the Dragon
Old Aug 14, 2006 | 09:29 AM
MSFITOY's Avatar
MSFITOY
Jim...it's the dang rubber boots...get rid of it and replace it with Alta's silicone boots...here why:
1-unless you find a way to mount the DFIC to the motor (I was going to make a new diverter and weld it to the DFIC so both were locked together), it will move side/side and up/down because the rubber is so flexible.
2-The side/side motion may cause your boots to eventually slip off if they're oiled up. The up/down can dent your hood if you have removed your hoodliner (which I found out the hard way...but was remedied by extreme dent removal Project M7 Louvers!).
3-The top seal (attached to the hood) is stiffer than the rubber boots and pushed the DFIC down past the first core...
4-Alta's silicone boots are rigid side/side and up/down...no movement...problem solved
Old Aug 14, 2006 | 01:07 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Hi Guys......
peter
Team M7
562-608-8123
props for great customer service Peter!
Old Aug 14, 2006 | 02:17 PM
hornguys's Avatar
hornguys
Thanks Sid,
Sounds good.
I'll give that a try.
Frankly, it works pretty darn well even with the bottom row blocked!
Old Aug 14, 2006 | 02:38 PM
MSFITOY's Avatar
MSFITOY
Thanks Sid,
Sounds good.
The bottom row should be in the clear once you do this...it worked for me...
Old Aug 14, 2006 | 02:50 PM
hornguys's Avatar
hornguys
Alta boots on the way!
I have another idea if that doesn't work.
Old Aug 14, 2006 | 03:03 PM
MSFITOY's Avatar
MSFITOY
See the bottom row?...oooo...bug stains Not to worry...I have another "project" to increase the efficiency of the already great DFIC...
Old Aug 15, 2006 | 01:08 PM
maxmini's Avatar
maxmini
Just a quick heads up. We have sourced a new silicone boot for the DFIC and will be placing an order when we return from the event this weekend. They offer a few colors . Other than basic black what would you like to see. Not that we can guatantee them but we will try to accomodate a few different if possible.
Randy
M7 Tuning
Old Aug 15, 2006 | 01:18 PM
latte hiatus's Avatar
latte hiatus
Randy
M7 Tuning
What a relief! GTT products are a PITA to acquire, and I'd rather not give any more of my business to Alta.
I'd love to see the IC boots in neon orange or pink , but I think blue would go better with the rest of my engine bay.
Can you give us any hints of how much these boots may end up being priced at, Randy?
Old Aug 15, 2006 | 02:14 PM
stevecars60's Avatar
stevecars60
Yup, blue would be good.
Old Aug 15, 2006 | 02:34 PM
MSFITOY's Avatar
MSFITOY
Randy
M7 Tuning
Now you tell me...:impatient
Old Aug 15, 2006 | 03:04 PM
maxmini's Avatar
maxmini
We will have a better idea price wise next week but lets just say that these will be more of a accomodation to our DFIC buyers and not something we are looking to make profit on. They will be as reasonable as we can make them and should be the least expensive on the market.
Randy
M7 tuning
Old Aug 16, 2006 | 04:55 PM
pberry51mini
No Fear Gear
Randy
M7 tuning
Count me in, and I'd like some in blue, black, or silver.
Maybe more of a darker blue than the ALTA ones.
Pablo
Old Aug 16, 2006 | 05:12 PM
TonyB's Avatar
TonyB
Agreed, a darker blue... think IB
Old Aug 16, 2006 | 05:40 PM
MSFITOY's Avatar
MSFITOY
I think we need a transparent aluminum version while we're all daydreaming...
Old Aug 16, 2006 | 06:16 PM
etalj's Avatar
etalj
ohh...
how about clear one's. That'd look awesome!
