Drivetrain Engine Light On: OBD code P1683 - Because of Mods?
Old Jul 23, 2006 | 12:12 PM
Ranzo's Avatar
Ranzo
Hi Everyone,
Okay so I've been modding my Cooper's engine a part at a time this year, first fitting an K&N intake, then a larger throttle body (M7), then the MTH Manifold, Magnecor wires and Denso plugs.
I noticed that after a put in the larger throttle body, idle was kind a rough periodically, it rumbles really hard like it's about to stall but then it goes away. I just put in the headers a few weeks ago and it seems like I'm stalling a lot especially when I have the AC on.
Last night I was accelerating off a red light, that rumble came on again and all of a sudden I lost lots of power (close to nothing) felt like I'm almost stalling but not really, engine light popped up. I turned off the car and it came back to life thank god.
I plugged in my Diagnostics tool and it read P1683: Electronic Throttle Control Monitor Level 2/3 Idle Speed 'B' Calculation Fault
My question: Is my Cooper's behavior due to my hardware mods minus the software? Is it getting confused because of more airflow? I haven't loaded my MTH tuner file yet because MTH USA is taking they're sweet freakin' time (almosts 3 weeks). If I load the file in will it fix the fault?
Your input is much appreciated! Thanks!
Randy
Old Jul 24, 2006 | 01:48 PM
Ranzo's Avatar
Ranzo
Weird. The engine light isn't on anymore. Nevermind! Thanks for looking anyways.
Old Aug 1, 2006 | 12:17 PM
Ranzo's Avatar
Ranzo
Darn it! Damn light came back on. Can a moderator move this to MTH Support Forum please? Thanks!
Old Aug 2, 2006 | 07:36 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
You should try to install the stock throttle body and see if the problem i still there...
Or check that the connectors on the TB plug are all ok ...
Old Aug 2, 2006 | 07:41 AM
Dr Obnxs's Avatar
Dr Obnxs
I'd second the TB connector.
It's strange, but I've found that the TB connector can seat a bit farther than is needed to get the lock to engage. Try making sure that the connector is really seated good. This is a fault from not being able to read the TB position pots well....
If the problem persists, you may have a problem inside the TB. Give PEter a call to arrange an exchange....
Matt
haulinS's Avatar
haulinS
it probably has something to do with the volume calculation in the software, since you are changing the amount of vol. coming in/out of the engine.
your Tuner file should take care of this. If you are not getting the Tuner file for a while, I agree that you should swap the stock TB back on there and see what happens.
Old Aug 2, 2006 | 11:00 AM
UberFisch's Avatar
UberFisch
I am going with a throttle body problem or connection problem as well- check that out first, then put the OEM TB in
Old Apr 13, 2007 | 04:15 PM
weezer2282's Avatar
weezer2282
I'm getting this same code with the stock throttle body on a 2005 MCSa. Only mods are CAI and 17% pulley. Even when the motor was completely stock it started rough in the morning when it was cold especially. Never threw a code until now at around 38k miles.
Old Apr 13, 2007 | 08:19 PM
Guest's Avatar
Guest
Originally Posted by Ranzo
Hi Everyone,
Randy
I'd say TB too. It was explained to me that the engine computer calculates a specified amount of air entering the engine during various stages of the intake sy.stem. When the MAF detects that based on the position the TB is in, it's pulling in too much air, it throws a code.
A lot of people have had the same problem .
ASRman
Aug 13, 2015 09:33 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
