Drivetrain So many intakes.. so little time
Old Mar 21, 2003 | 09:56 AM
merlin50623's Avatar
merlin50623
I just got my MCS about a week ago, so i am a little new to all the mini aftermarket products, and am looking to put a new intake in it along with some other performance mods. However, there seems to be a plethora of diferent intakes out there with no real comparing data. If someone could shed a little light on this for me, i would be eternally greatful. Thanks
Christian
Ps: Do you think i would be better off going for the pully first, i am on a fairly tight, still in college budget.
Old Mar 21, 2003 | 09:59 AM
2minis's Avatar
2minis
I can hear the thoughts in Randys mind churning...
RandyBMC...the man to talk to....
Old Mar 21, 2003 | 10:00 AM
IQQIMINI's Avatar
IQQIMINI
Coordinator :: Mid-Ohio Motoring Club
Christian,
Congrats on your new MINI.
I am also on a budget, and after apeaking with Randy, selected the Madness intake. I ordered it today.
That's my suggestion... better power, better install, better sound, better feel. And more money ($240) than the BMP or Pipercross. I trust Randy when he says it's worth it.
Old Mar 21, 2003 | 10:01 AM
dominicminicoopers's Avatar
dominicminicoopers
Randy has some nice comparison data and text on the more popular intakes on http://www.mini-motorsport.com
Old Mar 21, 2003 | 10:11 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
merlin,
Welcome to MCO!!!
There is actually quite a bit of information comparing the latest and greatest intakes on the market right here on MINICooperOnline. I'll give you a cursory glimpse, but use the search function up in the right corner in little yellow letters. Put in the keywords Intake and my name, you'll get a ton of info.
BMP - great system, usable with the strut brace, allows a small amount of underbonnet air into the intake through the very back of the heat shield. Excellent fit and finish. 4-6 horsepower consistently on a warm car. $170
Rogue/Madness - Very high quality fit and finish. Largest filter element completely sealed wiht a heat shield from the under bonnet air. 7-9 horsepower consistently on a warm car. $240
Pipercross - Somewhat lacking in the fit and finish, but a nice filter element that uses an aluminum bell intake to the throttle body hose. Similar power to the Rogue. $215
K&N - Great fit and finish. Uses a heat shield that does not keep the under bonnet air free from the intake at all. Uses replacement tubes for the snorkle and throttlebody pipes (good) made out of aluminum (not so good). Dyno tests similar to the Madness/Rogue - but once the bonnet is shut, power does fall off. $350
Monster - Very similar to the K&N issues, but with no heat shield at all. $230
Hope that helps!
Randy
Old Mar 21, 2003 | 10:41 AM
merlin50623
Thanks guys..... any thoughts on the pully??
Christain
Old Mar 21, 2003 | 10:45 AM
chrisneal's Avatar
chrisneal
>>Christain
Again, use the search function (but spell it right - pulley). There's been quite a lot of talk about it in these forums, including very recently.
Old Mar 21, 2003 | 10:48 AM
Davbret's Avatar
Davbret
>>Christain
Unless you are planning to install it yourself, and really are on a tight school budget, this is not for you. Granted the pulley costs about $200, but you are looking at around 4 hours of labor charges to install it....making it more in teh $500 install range. Seems a bit high if you are concerned about budget.
But if you are going to install it yourself (like I plan to) it's a great mod for a small cost.
As for intake, unless you are hell bent on a strut tower brace (not needed in this car, IMHO) go for the Madness intake. If you must have the brace, get the BMP.
R
Old Mar 21, 2003 | 05:58 PM
greatgro's Avatar
greatgro
R,
True, we don't know his budget. HOWEVER, pulley and install can cost as little as $450. $450 vs $240 for up to 17lbs of torque vs 7-9HP, you never know. If I could only get ONE mod, from what I now know, it would be the pulley. But if you can only get one mod now, with others down the road, yeah, I think the intake is effective and easy so that would prob be best bet.
bjcarter2
Aug 31, 2015 04:03 PM
Aug 12, 2015 01:24 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
wind715
Aug 11, 2015 07:56 AM
