Drivetrain Cravenspeed Tech Q&A
Old Jun 13, 2006 | 12:54 AM
  #26
Bster's Avatar
Bster
sorry... double post.
Old Jun 14, 2006 | 04:54 PM
  #27
Spankinsum's Avatar
Spankinsum
Thank You for the great customer service and your attention Loren.
Awesome
Old Jun 15, 2006 | 04:56 AM
  #28
blueheat's Avatar
blueheat
Thanks for your support of the USMINICLUB.com event in May. The team there was a great help to us.
And..I am loving my new Craven 15% pulley. That nice little red spot under the bonnet makes me smile every time.
Old Jun 15, 2006 | 01:54 PM
  #29
StayTuned's Avatar
StayTuned
Awesome
Glad I was able to help. Me, Tristan and the rest of the Team Craven are here for you!
Old Jun 15, 2006 | 01:57 PM
  #30
StayTuned's Avatar
StayTuned
Tristan told me they hijacked your car and did the install in 20 minutes!
Loren
Old Jun 16, 2006 | 08:38 PM
  #31
blueheat's Avatar
blueheat
Loren
I call it the stealth install. I think the "official" time was 23 minutes. Also consider it was in the middle of the MINIQ auto show, outside under a big tent and in front of a large crowd. They got me to run out w/someone else for additional supplies. Seems at least 30 people knew, including my wife. I did not find out until almost 4 hours later when someone ask me to go for a quick ride. It was then quite obvious, but I still did not believe it until I lifted the bonnet. Joke was on me but all I can say is .
Good to meet the team and thanks again for the support.
Old Jun 17, 2006 | 04:38 PM
  #32
Dr Obnxs's Avatar
Dr Obnxs
This wins...
Hi INGSOC,
They look similar to me too.
The "Ultimate in Diplomacy" award!
Matt
Old Jun 17, 2006 | 08:08 PM
  #33
ingsoc's Avatar
ingsoc
Matt
Yes, yes, Cravenspeed for President?
Old Jun 19, 2006 | 04:47 PM
  #34
simplygriff's Avatar
simplygriff
Coordinator :: Tar Heel MINI Motoring Club
Thought I'd drop you guys a line just to show off your wares a bit more. The shifter well cover looks much better with the shaft of the shifter in matching black. I had a different **** so I'm using the UUC one with the adapter for the stock ****. Overall it's a real nice product guys. Thanks. Oh and thanks again for the beer at the Dragon. I was chilling with you guys on Saturday night standing by Dan's car listening to reggae out in the parking lot. Good times!
UUC Motorwerks RK3 Shiftknob sitting on a Craven Speed Adjustable Short Shifter with Shift Well Cover
A Big Shout Out to Dan @ Grassroots Garage (you guys know him as onefastmini) Thanks for all your help and for talking me into the shifter cover.
-G
Old Jun 20, 2006 | 01:23 AM
  #35
Bster's Avatar
Bster
I'm sold. Thats it, I'm putting in my order!
Old Jun 20, 2006 | 01:47 PM
  #36
sdv515's Avatar
sdv515
definately, that looks sick.
Old Jun 21, 2006 | 06:20 PM
  #37
StayTuned's Avatar
StayTuned
-G
Thanks for the props, man. Cheers to Dan as well.
I'll go ahead and take this opportunity to let everyone know that you're invited to post pics of your Craven Speed setup here anytime.
I'll tell Tristan and Jason that you remember them.
Old Jun 21, 2006 | 06:21 PM
  #38
StayTuned's Avatar
StayTuned
Great! I'll put you down for 10? 20?
Old Jun 21, 2006 | 07:20 PM
  #39
Grassroots Garage's Avatar
Grassroots Garage
Actually, it fitting losely is my concern. This hub just slides on without any restriction. basically lose. Like the bolt will be the load bearer and holding on for dear life. I was expecting for it to be interference fit and hoping the anodizing would keep it's color, but to my surprise, well you know.
The best way I have found to install the crank pulley is to just use the bolt to press it on, but it needs to be torqued properly to 85 ft.lbs. The way to do this is, is to use a tool which is a bolt that you put in the #1 spark plug threads, it has a brass end so as not to damage the piston. I found this out the hard way when the pulley came off at VIR. You can find this tool here http://www.tooltopia.com/index.asp?P...OD&ProdID=4744
--Dan Zipkin
Old Jun 22, 2006 | 01:50 PM
  #40
Spankinsum's Avatar
Spankinsum
--Dan Zipkin
Hello Dan
The pulley slides on and off the crank shaft without a problem. So there is no need to press it on with the bolt. The ft lbs you add to the bolt is useless if the pulley just slides on the crank shaft, but you should always torque all bolts. Even assembly lube and loc-tite, if need be. If the tool you refer to is to hold the crank from spinning while you turn...via blocking the piston...ooch! Geez, if the motors in the car and you have a tranny with driveshafts in tact... you could just have someone hold down the brake.
Interference is the way to go (just heat it up so it expands) and the pulley ultimately had a minor overbore.
I was driving at a pulley issue not a How to.
Old Jun 22, 2006 | 03:29 PM
  #41
Grassroots Garage
Hey Spankinsum,
It does sound like a pulley issue, I hope it's resolved. Perhaps my post can serve as a how-to for others. I have installed a few dozen crank pulleys with this method and no further issues. The brass end on the piston lock does not damage the piston, and I found holding the brake does not allow for the proper torque to be applied through twisting of the drivetrain via the mounts. I do recommend blue loc-tite on the threads, however should not be necessary to apply to the crank. It should be a tight interference fit, and heat should also not be needed.
Happy Modding,
--Dan
Old Jun 22, 2006 | 09:01 PM
  #42
Bster's Avatar
Bster
Hang on to ya horses! I'm waiting for pay day to come... Blew my budget for this month on rims! But it's all good!
Old Jun 23, 2006 | 04:59 AM
  #43
Spankinsum's Avatar
Spankinsum
Hey Spankinsum,
Happy Modding,
--Dan
Gotcha... Figure the engine movement is regardless of how you hold the crank.. I had used a bracket to hold the motor in place while torqueing.
Old Aug 9, 2006 | 09:50 AM
  #44
MSFITOY's Avatar
MSFITOY
Can anyone describe the install and how the ratio is adjusted?
Also, there appears to be a cover plate that slides with the shaft...can this be left off so the pivot will be exposed?
Old Aug 9, 2006 | 10:27 AM
  #45
HAPA's Avatar
HAPA
anodized red ball shift ****???
Hello,
I was wondering if you guys would be able to make a round ball shift **** just like the one Whallen sells but in anodized Red alluminum that i could then send to whallen for engraving?
Thanks a bunch
-HAPA
The wearing the Kilt at the dragon.
Old Aug 9, 2006 | 10:31 AM
  #46
MSFITOY's Avatar
MSFITOY
bump
Old Aug 9, 2006 | 11:33 AM
  #47
pdxtdi's Avatar
pdxtdi
Hi MSFITOY,
I'm not sure what you mean by ratio adjusted... You're talking about the Shift Well Cover, right? There is a dust plate the sits firmly against the bottom of the cover using a foam spacer and slides easily back and forth.
The install is VERY easy--should be 15 minutes or less. You can leave out the dust plate to reveal the main pivot if you like. But you may end up collecting dust...
Hope this helps!
Old Aug 9, 2006 | 11:41 AM
  #48
MSFITOY's Avatar
MSFITOY
Originally Posted by pdxtdi
Hi MSFITOY,
Hope this helps!
Thanks...I was wondering how the shifter's ratio is adjusted...the ****...I assume that it tightens/loosens to allow the shifter shaft to go up and down?
Old Aug 9, 2006 | 12:51 PM
  #49
cliff@coasttocoastusa's Avatar
Former Sponsor
There is a adjustment **** in the middle of the shaft. Loosen this **** and you can raise and lower the hight/ throw of the shifter. Changing the throw takes about 10 seconds if you have the shift well cover as the adjustment **** is exposed.
-Cliff
Old Aug 9, 2006 | 12:56 PM
  #50
mini-rolls's Avatar
mini-rolls
The ratio of change for the shifter is about 50% of stock. So in the down position you reduce the throw greatly. I show people mine all the time and they can not believe the difference.
