Drivetrain Webbmotorsports HDI box install question
The bottom of the box is held in the back by 2 rubber grommets (or whatever you want to call them) attached to two bolts.
Once the entire box is loose you have to pull the box forward (toward the bumper). Pulling the box up is useless as the rubber pieces fit into a hole in the base of the box.
Just walk out there and pull it straight forward and then up and it should come free.
chris
chris
it is attached to two screws threw the bottom petition with little rubber things, and it also held in by the air duct coming from the front of the car. just pull that out then yank it and is should come out
How do I get the cable through the hole that is attached to the fuse box?
Do I attach the HDI box to the lower box first then put it in or put the bottom of the box in then attach the HDI box to the bottom of the box?
i dont remember putting a cable through that hole. i think that is there for that metal piece on that white tank. (sorry i dont know what anything is). i put the two screws in first then the bottom of the air box got pushed onto that with the grommet things. then i put the hdi piece in. i had trouble with the wiring harness and getting it to fit through that slot.
I am expecting mine any day now....from the sounds of this thread and I may be wrong but did the HDI not come with any instructions?? I was told by Brian over at WMS that the install is very similar to the Alta CAI install instructions...anyone have those handy?
Here's a couple pics. Sorry for the size I'm in a hurry.
Try to ignore the UNIChip cables unless you have one.
There's a couple more pics from my web page
Hope it helps.
TBH didn't have to remove the bottom half since I had run an Alta for years so I don't remember that part but the above posts have it right from what I remember.
PS:
You can see the bits of gray insulation by the wires. It's on both sides of the slot. I'd recommend using something there cause eventually the edgs will abrade the wire insulation. I keep forgetting to buy a good grommet to install.
I found the instructions on Webb Motorsports Forum:
http://store.webbmotorsports.com/for...wtopic.php?t=3
i was getting scared when i saw extra wires. i thought that maybe i left something disconnected. i tried looking on the website yesterday for instructions but it was down. now all i have to do is wait for the tube i ordered. never came with the hdi
I got my HDI in the mail today....thanks WMS! I also ordered a 15% pulley and since the airbox has to come out for the pulley install... I will just wait until my scheduled appointment to get it all done at the same time. There is no use in getting it installed and then watching the shop (Lucky Dog Garage) take it right back off again for the pulley.
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
Jan 30, 2021 01:35 AM
squawSkiBum
Oct 2, 2015 09:21 AM
