Drivetrain Spark plugs and pulleys go like peanut butter and jelly???
Originally Posted by -Jonathan-
Hey guys, real quick....I asked this a few posts up:
"Oh and one more question about the oil film accumlating in the engine. Aren't there cleaning oils specifically designed to eat that stuff away once in a while? If so, that may be the safer answer, instead of risking an engine explode due to a cramped cable. Sometimes you don't know if those cables cramp, because they look fine when the bonnet's open, but when you close the bonnet, they may cramp badly!"
If someone could maybe answer that, I'd appreciate it. Then you all can return to your spark plug talk.
Thanks!!
Thanks!!
Modern engine oils do contain detergents. and yes they do help.
But will they clean out oil contaminant deposits? Particularly in the intake track? Not really.
Originally Posted by latte hiatus
But I still don't quite comprehend how colder plugs could potentially cause more damage to the engine than stock plugs
After all, isn't detonation caused when the fuel mixture is ignited somewhere in the combustion chamber,
but that also goes against Eric's finding that detonation occurs at the same rate regardless of the heat range of the plugs.
Originally Posted by rl48mini
I don't know if this will help or not...
I think Eric is proposing to create a known "weak link" in the ignition system. In that respect, the stock plug will fail (assuming one of the above mentioned senarios occurs, ie, bad gas, bad knock sensor, whatever) before any (much more) serious engine damage might occur. It's not that it WILL occur it's just that it might. This way, the plug failure will prevent the other more expensive problems...
Originally Posted by dominicminicoopers
Eric only checked one heat range of plugs colder than stock. And only checked one manufacture of plug. And only checked one plug metal type, that being "iridium". This certainly, as I'm sure Eric would agree, was not a comprehensive test. Just some initial findings that need more data points in order to make an complete assessment of the situation.
after i had to replace a bad injector my local bmw mech. also replaced my denso ik22's with stock plugs.( i have a 15% pulley,magnaflow,obx headers, and alta cai) after, on fairly hard acceleration' i kept hearing a slight pop like a quiet decel burble. so, i changed plugs to a set of NGK iridium's one heat range colder than stock. have not heard the pop since.
did u see tha ik22's after they were removed, if so how did they look?
the codes indicated a bad #1 injector and the mech. found it stuck closed and was able to unstick it. i replaced it a week or so later. i think my mech. would agree with Eric and prefers the stock plugs. i did tell him what i did to alleviate the popping and he wasnt sure that was a definitve fix but so far it seems to work.
eliseo1981
May 10, 2016 05:19 AM
Sep 2, 2015 09:05 AM
