Drivetrain Spec Clutch & UUC flywheel install help
Old Apr 7, 2006 | 01:24 AM
pyugala's Avatar
pyugala
Hi guys,
I need some help here with the installation of the Spec clutch & UUC flywheel. My car is now in the workshop with everything apart await to put them back togeter.
The mechanic told me that I need the 6 bolts that hold the clutch pressure plate to the flywheel. Which bolts should I use, does the bolts on the standard flywheel work? Or should they be supplied together with the UUC flywheel? :impatient
Please help.
Cheers
Old Apr 8, 2006 | 08:27 PM
002's Avatar
002
My kit came with new bolts from spec, but the pressure plate bolts should be re-usable if you must. The flywheel bolts are shorter on the lightweight version, if I remember right.
Old Apr 8, 2006 | 10:08 PM
maxmini's Avatar
maxmini
Yopu might want to give Steve at Steve's Auto Clinic call. He has had a lot of experience with the UUC lately as a couple have come apart . I am not sure of the details but I know he has replaced 2 recently. His shop number is 818 891 6109.
Randy
m7 Tuning
andrewjg1994
Jan 29, 2021 07:45 PM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Sep 17, 2015 09:27 AM
