Drivetrain Crank pulley survey
Old Mar 31, 2006 | 11:14 AM
MINIotaple's Avatar
MINIotaple
Crank pulley survey
Somebody brought up this idea in the supercharger pulley thread and since I had some time, I threw together a table. You guys can PM or post on this thread and I will update the table. I'll probably update the first post with quotes of the problems in the first post. If you guys have any feedback, I'm open to suggestions.
Updated: 15 February 2006, 5:04PM
Originally Posted by mdsbrain
0% lightweight crank on for 3k miles. I removed it due to car vibrations and the ecu couldn't keep up with the engines revs to know when to shift.
Originally Posted by latte hiatus
Alta 15% pulley and M7 2% crank pulley, approximately 1000 miles, some vibration around 2800 - 3300 RPM, and some pre-ignition pinging (probably due to the combination of the extra boost and poor CA petro).
Originally Posted by aokdoug
ran 19% for 2 years. no problems. 20,000k
installed alta crank pulley & new gator belt 2000k ago.
last week had lost of power. pulled over &saw that i hade lost a belt.
i thought no problem as i carry a belt&the tool with me for just incase.
jacked car up &removed finder liner& to my dismay saw all the pulleys were trash. the adiler pulley stop had failed &allowed it to foul it all up. had car towed 200 miles to dealer (ferman in tampa) &found out the super-charger
had locked-up causing the mess. of course no warrantty because of mods.
standard light weight alta with 19% helix.
changed to a alta 19% & a new standart alta light weight.
Originally Posted by SteveS
35,000 mi on car now.
at 3500, Randy inst. 15% pulley, no problems at all
30,500 installed 2% Alta pulley. Non-Mini guy did it. There was immediate slight vibration/rattle and roughness at low revs, like at takeoff or lugging engine.
32.500 new belt tensioner installed. (on warranty).This reduced the vibration a little. but it was still there and a concern.
34,000 I personally Ireinstalled a 2005 stock crank pulley that Randy gave me.
Originally Posted by maxmini
Sorry about the delay but we wanted to have all of our ducks in a row on this one . In testing the M62 we discovered a entirely new issue . We have joined the ranks of a few cars that have discovered that high RPM and light weight crank pulleys do not play well together . I have a red line of 7200 and have not had a issue and I have many miles on this as it was our first unit built. Based on this recent development we are cautioning anyone with raised rev limits to be cautious when thinking about lightweight crank pulleys.The car in question has a custom software pkg which allows for a red line of 8250 RPM and the car has hit that many times in the months prior to the m62 install. Well to be specific the oil pump gear decided it had enough and let go thankfully at idle but some pieces bounced around in the oil pan, got into the crank and took out a piston which put a hurt on some of the internals. The motor is being rebuilt as we speak and we hope to have more info as soon as possible. Again sorry for the delay but we wanted to do a through post mortem and make absolutely sure it was not M62 related.
Randy
M7 Tuning
Originally Posted by bomboasy
-15% Alta installed at 5K 2 1/2 years ago, Randy Webb did it. +3% Alta installed at 21K by Khuevo. I wrote a DYI for this installation. +5% Altanator installed at 22K by myself. No problems. No issues. Some vibration after the 3%, but not a lot more than what was there since I installed the engine damper that ties the engine to the frame. I do not race, but I drive like I stoled it sometimes.
Bomboasy
Old Mar 31, 2006 | 11:28 AM
RECOOP's Avatar
RECOOP
Alta 2% crank pulley with Helix 15% SC pulley...
2500 miles with no problems...
Very nice combination so far...
Old Mar 31, 2006 | 11:44 AM
mhhoff's Avatar
mhhoff
Alta 2% crank (15,000 miles) with Madness 15% SC (70,000) . . . perfecto
ted leist's Avatar
ted leist
Alta 15% SC pulley - 40,000 miles - no problems
Alta 4% crank pulley - 15,000 miles - no problems
Old Mar 31, 2006 | 11:59 AM
mcnamaraz's Avatar
mcnamaraz
M7 pulley. 500 miles on mine so far, no issues....installed by Webb. Quicker throttle response, no vibrational issues so far. Coupled with Alta 15% reduction SC pulley.
Old Mar 31, 2006 | 02:35 PM
MINIotaple's Avatar
MINIotaple
Should I include what size supercharger pulley it's paired with? What about self-installation vs. professional installation?
Old Mar 31, 2006 | 02:43 PM
F15EWeapon's Avatar
F15EWeapon
Alta, 2% (with 15%) 4000 miles, ZD. (Zero Defects)
and MDSBrain... you're blaming the pulley?! Aren't you the fella with the whole engine out for a bad block? Vibrations indeed!
Old Mar 31, 2006 | 09:11 PM
not-so-rednwhitecooper
LOL
I have THE puley that was on Mdsbrains car on my 04 MCS.
I bought it off of him after he took it off.
I have ABSOLUTELY NO vibration problems in my car!
I think you also should add wther or not the cars are autos or stick, I believe Mds is the only one ive heard of with a crank pulley problem, and he is the only auto in the group listed.
Old Mar 31, 2006 | 09:25 PM
mininutz's Avatar
mininutz
Yes, excellent idea (size does matter since it's considered safest to run no more than 2% oversized crank pulley with a 15% undersized S/C pulley to avoid belt problems). I'm an amateur, but I'm about to install mine in a couple of weeks. I expect to screw it up somehow.
Old Mar 31, 2006 | 10:01 PM
MINIotaple's Avatar
MINIotaple
Originally Posted by not-so-rednwhitecooper
LOL
Mileage, supercharger pulley size?
Unless there's some factual basis for the correlation of crank pulley problems and automatic transmissions, I don't really want to add it since at this point it seems like just a spurious correlation. I don't want to give the impression to people that only automatics have crank pulley problems. On the other hand, if you have some evidence that crank pullies do not work on automatics, I'd gladly add it.
Old Mar 31, 2006 | 10:06 PM
04yellowS's Avatar
04yellowS
Alta 0% with 19% pulley. 4000 miles, no problems.
04 MCS
Old Mar 31, 2006 | 10:23 PM
AZMCS's Avatar
AZMCS
SC: Alta 15%
CP: Alta 2%
Milage: 9k
Problems: zero
Old Mar 31, 2006 | 10:37 PM
maxmini's Avatar
maxmini
Of course the brands used won't be a suprise LOL
M7 16%
M7 2% crank
7,000+ miles with track days no problem
Randy
M7 Tuning
Old Mar 31, 2006 | 10:48 PM
hyper blue 06's Avatar
hyper blue 06
Hi,
Anyone have a 05 or 06 OEM crank pulley they would like to sell?
Thanks,
Graham
Old Apr 1, 2006 | 05:23 AM
latte hiatus's Avatar
latte hiatus
I don't really consider those to be significant problems, though the pinging definitely needs to be rectified, I can live with a slight vibration as a trade-off for the excellent throttle response and overall performance from the lightened/oversized crank pulley.
Old Apr 1, 2006 | 10:10 AM
SCA's Avatar
SCA
Alta 2% (Webb installed)
JCW kit (so a little less than 15% SC pulley)
2000 miles with the Alta
no problems
Old Apr 1, 2006 | 12:48 PM
No SC pulley on mine.
MDS's 0% crank.
about 1500 miles. no problmes whatsoever.
as far at the tranny goes, i think MDS made a point, about the auto tranny thinking the engine is revving faster than it should (or should i say faster than stock) and its confusing the computer.
i dont do FWD cars often, so im not sure if that can be calculated in , but its something to consider.
Old Apr 1, 2006 | 12:49 PM
MINIotaple's Avatar
MINIotaple
Surprised, didn't think there would be any others than mdsbrain.
Old Apr 1, 2006 | 02:35 PM
mdsbrain's Avatar
mdsbrain
MDS's 0% crank.
Right, the car's ecu couldn't keep up with the revving of the engine and it wouldn't know to shift in time. This caused my rev limiter to rise to over 7k. In auto or manual mode.
Old Apr 1, 2006 | 02:59 PM
well it must mean somethen when i put the pulley MDS had on his car on my car and you get two different outcomes with the same pulley.
that leads me to believe that this might be a tranny issue also.
Old Apr 1, 2006 | 04:45 PM
///ACS330Ci's Avatar
///ACS330Ci
Anyone know where I can find a crank pulley DIY?
TIA
Old Apr 1, 2006 | 05:01 PM
AZMCS's Avatar
AZMCS
TIA
Come on Steve, keep it ON TOPIC. j/k
Seriously, we don't need no stinking DIY. Bentley, blowtorch to heat up the shaft and we can do it. Seriously.
Old Apr 1, 2006 | 05:06 PM
///ACS330Ci
I posted a separate thread about a week ago and got no love
I wouldn't have to ask for a DIY if you would have paid attention when Mr. Webb installed yours
Old Apr 1, 2006 | 05:25 PM
SpiderX's Avatar
SpiderX
Updated: 1 April 2006, 2:44PM
I have had mine on for at least 10K with no problems 0% w 19%
Old Apr 1, 2006 | 05:35 PM
CFMINI's Avatar
CFMINI
Alta 15% pulley (56,000 miles) no problems - now 88,000 miles
m7 2% crank pulley (9,000 miles) no problems - now 32,000 miles
Have MTH ECU flash with 7200 RPM rev limit - I am rarely above 6500 - got flashed back to to stock after a MINI recall - 6750 RPM limit
Last edited by CFMINI; Jul 24, 2007 at 12:55 PM. Reason: Time flies - and so does my MCS
